help, 700r4 output housings swap 83 to a 92 ! ?
Old Apr 26, 2003 | 12:14 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
delete
thanks
Old Apr 27, 2003 | 05:00 PM
lbrohez's Avatar
From: Decatur,, IL USA Search Posts:NONE.............. Whore Posts: All.................
the output housings are able to be changed but you can take the housing off, and put the gears for mechanical speedo in and us the output housing you took off, but you can change the whole thing
Old Apr 27, 2003 | 08:51 PM
ArrioZ28's Avatar
Something comes to mind in this speedo swap about lube provisions for the speedo gear. I may be mistaken, (I'll have to look this up if I can remember it tomorrow) but there is an orific near the govenor shaft boss that squirts lube oil at the speedo gear assembly. On the later 700R4's with the VSS/(edit)reluctor, this orifice is either blocked off with a plug or not there.
There could be a lube problem down the road with this conversion, and result in premature wear on the speedo parts.
Anybody else recall this issue?
(edited to reflect vss/reluctor)
Old Apr 27, 2003 | 10:03 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
No, I do not.
But the tailhousing for a 1983 Z28 is serviced with the same PN as one for a 1992 Z28.
Matthew
Old Apr 27, 2003 | 10:12 PM
jmd's Avatar
jmd
Originally posted by Fast68
does anyone know if i can swap output shaft housings from an 83 over to a 92 in order to make the 92 700r4 into a mechanical speedometer ?
please say it can be swapped without remving output shaft !
thanks for anything at all!!!!
Yes!
Instead of the VSS assy./driven gear, you need a speedo gear sleeve and driven gear.
Matthew
Old Apr 28, 2003 | 07:28 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i kinda forgot to mention i am converting an 83 700r4 to VSS so it wil work in 92 that does have VSS
i have found out that i have to press the VSS "gear" off the 92 output shaft and press it onto the 83 one somehow
thanks
Old Apr 28, 2003 | 10:08 AM
jmd's Avatar
jmd
i kinda forgot to mention i am converting an 83 700r4 to VSS so it will work in 92 that does have VSS
Are you doing both?
Read my third post in this thread: https://www.thirdgen.org/techbb2/sho...hreadid=175671
Old Apr 28, 2003 | 11:26 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
sorry, no, just putting 83 style 700r4 into a 92 with VSS, thats the whole deal, i gotta figure out how to VSS the 83 one
thanks@
Jeremys87
Jul 14, 2022 09:08 PM
camaro11j
Sep 19, 2018 08:49 AM
E Rod
Aug 28, 2015 05:17 AM
sreZ28
Aug 14, 2015 07:48 PM
