clutch problem???
Old May 7, 2003 | 06:10 PM
84fire's Avatar
clutch problem???
I just finished putting in a new transmission in today, and I went to drive it and it wont go into gear, but if you put it in gear than start the car it starts moving. I had this happen about 1.5 years ago and i replaced the whole master/slave cylinder assembly. Does anyone know how to fix this without me buying a new one?
Shawn
Old May 7, 2003 | 08:06 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
sounds like the clutch isnt releasing, did you bleed the slave cylinder? did you put in the correct throwout bearing?
Old May 7, 2003 | 09:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/techbb2/sho...hreadid=175173
Old May 9, 2003 | 10:56 PM
84fire's Avatar
the throw out bearing is the right one, and i did put it in properly and i tried bleeding the slave cylinder and it still doesnt work. I heard that it might be the clutch pressure plate or the syncronizers in the tranny, anyone heard of this?
Shawn
theshackle
Aug 31, 2015 10:47 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
