Broken tranny mount?
Old May 8, 2003 | 03:31 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
im pretty sure i have a broken tranny mount on my 700r4. i hear/feel a thump under the floor board. is there only one mount? is it right above the crossmember under the transmission? it doesnt look broken but then again i dont know what to look for. can u help me
Old May 8, 2003 | 03:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Has it been replaced with a poly one?
Then it's broken.
Just get an Energy Suspension one and be done with it.
Old May 8, 2003 | 03:43 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
I just replaced mine in a 5spd car. It is right above the crossmember under the tranny. It only took me about an hour to do it. (getting car jacked up, getting tools, ect.) Heres a pic of what it looks like. It makes it real easy when you take the crossmember off too
Old May 8, 2003 | 03:46 PM
cr125r's Avatar
Car: 1988 trans am
i started taking the crossmember off, but on the second bolt...it broke
sucks. is it necessary to support the tranny while doing this? is it ok for me to drive ot the parts store with only 3 bolts in?
Old May 8, 2003 | 03:53 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
I don't know if you need to but I did just to make sure I didnt break anything.
Are you refering to the bolts in the crossmember? If you are I think you should be ok to drive like that for a little bit.
Old May 8, 2003 | 04:07 PM
cr125r's Avatar
Car: 1988 trans am
yes i am. thanks a lot for your help, i am now off to buy a new tranny mount.
Old May 8, 2003 | 04:27 PM
Strunthopht's Avatar
I'd go with an aftermarket one
the OEM is like 10 dollars less than the after market (which is better)
so I'd splurge..
I had the same problem, peaked the hell out of me, till I figured out what it was..
Old May 8, 2003 | 04:46 PM
jeff1367's Avatar
I helped a friend replace the trans mount on his 89 Iroc a few days ago, and it was a really easy job. You do need to support the trans with a jack and a piece of wood or something, and I recommend doing this with the car on the ground if at all possible, because we had one side jacked up, which pushed the frame apart a little, and when we tried to put the crossmember back on, it wouldn't fit!
Old May 8, 2003 | 09:02 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
Hey guys, Mine is broken also. When ever I step on the gas more than half way It sounds like the tranny is slamming the bottem of my car.
I need to know where\how much\ what kind of tranny mount to get. Where exactly is it? All of your guru info will be awesome. Thanx guys.
Old May 8, 2003 | 09:05 PM
cr125r's Avatar
Car: 1988 trans am
i just went and go tmy mount today. i got the oem on because they would have to order and aftermarket one, and i didnt couldnt wait. if u arent going to do it for a while, get the aftermarket one.
Old May 8, 2003 | 09:26 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You don't have to remove the crossmember to do a trannie mount (at least on a 700-r4 I know). Just get a floor jack with 2x4 and jack it up under the trannie high enough to hold the transmission unbolt the 3 bolts on mount jack it up more and the mount should come free... if it doesn't come loose and is stuck put the center bolt back on tight (which means lowering the jack) and jack it up again... that way you pull the mount off the trannie and give you clearance. You can slip the old mount out and the new one in with a little working. Retighten the bolts you're good to go.
I did my spohn tq arm which had to replace crossmember... man it was a pita. I had to impact one of the bolts loose then the new crossmember wouldn't go back on.. I ended up getting a 4 inch or longer bolt to use on one side cause I had both bolts on the opposite side... when I did that it was easier to remount the crossmember again.
Old May 9, 2003 | 05:35 AM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
the tranny mount is just behind the pan, in between the crossmember and the tranny. very easy to change. i have done it atleast 6 or 7 times. i just jacked up the car, used a bottle jack and jacked up the tranny and if comes right off everytime.
you should also replace your torque arm mount while you are under there. pretty simple job if you have wrench to take off the torque arm. i didnt!. if it goes bad, you will get a clunking sound everytime you go into drive or reverse.
Josh
Old May 9, 2003 | 06:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://store.summitracing.com/partde...NS%2D3%2D1108G This is what you should get.... $21
Old May 9, 2003 | 08:29 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I got my ES Poly Mount from AutoZone. All of the AZ in my area are carrying them now. I would check there.
Old May 9, 2003 | 09:45 PM
87irocz350's Avatar
Car: 87 Iroc
Hey, thanx alot you guys. Im seventeen and Im going to be tackeling this one my self. But it sounds simple enough. Thanx for all the imput.
Peace out.
Old May 9, 2003 | 11:48 PM
Car: 1990 Iroc-Z
if you have any problems...(not that you should) you can contact me on AIM. my name is dEfUs3d. good luck man.
Old May 10, 2003 | 05:31 AM
DaisyCup26's Avatar
Want a title? Post!
One of my front brakes locked up last year and I had to take my beloved 86 T/A to Meineke Muffler....and against my better judgment, I left her there overnight. When I picked her up the next day, all of the mechanics kept staring at me and acting weird. After I left the place, I got on it a bit to see how things felt. I discovered that when I even halfway floored it, the transmission lurched and felt like it was coming up through the floor. I immediately turned around and went back to Meineke, and as I pulled in the parking lot I noticed that in the side lot (which was gravel) there were a large quantity of deep donut marks that hadn't been there when I took my car in. As it turns out, the rat bastards had ragged on my baby so hard that they broke the transmission mount. AND I had to pay an extra fifty bucks to get it fixed. I raised hell but there was nothing I could do, they said it was already broken. I know my car like I know myself and that mount was not broken beforehand. I can only imagine what they did to her. My car has never been the same since.
NEVER GO TO MEINEKE MUFFLER IN BLOOMINGTON, INDIANA
Old May 11, 2003 | 05:47 PM
Car: 1990 Iroc-Z
thats some bs!!
i would have made a couple trips back up tp that shop with some bricks!
lolz.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
