new gears and rear
Old May 25, 2003 | 03:53 PM
unvc92camarors's Avatar
new gears and rear
alright here is what im plannin on..
zexel torsen lsd- from slponline.com
motive 3:73 gears(i have 3:23's presently)- thunderracing.com or somehwere
disc brakes from old z28 or something- junkyard
new speedo gears- slponline maybe
install kit for new gears- somewhere
now a few questions...
1) do i have a electric or cable driven speedometer? (92 3.1 RS)
2) what is the most basic install kit that i need (cheapest too) and where can i get it?
3) what else do i need for disc brakes install? i heard something about a longer ebrake cable or somethin i think.
4) what kind of price should i pay for disc brakes only?
5) anyything else i need?
6) how do i go about readjusting shift points so i can get the full gain out of it?
ok, so maybe that was more than "a few" questions
edit: i already found the equation from omar for calculating speedo gears, so i dont need any help on that
Old May 25, 2003 | 05:17 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
where did you find the equation for calculating the speedometer gears?
Old May 25, 2003 | 05:26 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Electric
Get the Ratech kit from Summit. Don't get the "basic", get the one with bearings
Disc brakes used different cables. There are three total on the car, you only need the rear two. You'll have to look them up for whatever car you rob the brakes from
Hard to say, some people rob you blind, others practically give them away. If your going to buy used, shop for '89 or later aluminum PBR calipers
Thats a loaded question, you won't know untill something breaks... You might need a prop valve to accomodate the disc brakes. Some say you do, some say you don't. Because there is a different one listed for disc then drum, I replaced mine.
If the shift points are not where you want them after the gear swap, you can get a Governer calibration kit. Its an assortment of secondary weights and springs that will adjust your WOT shift points. If you can't find one, let me know, I have a few Superior kits laying around
Old May 25, 2003 | 06:27 PM
for 86transam..heres the link for speedo equation https://www.thirdgen.org/techbb2/sho...r+change+gears
will this work for adjusting shift points? http://www.jegs.com/cgi-bin/ncommerc...87&prmenbr=361
if i buy disc brakes, does the prop valve come on z28's and stuff?
and is the ratech kit with bearings really recommended? im asking because im on a real tight budget
Old May 25, 2003 | 06:40 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you want to put all that stuff in, and try and re-use old bearings, then you may as well put all the parts in a box and wait untill you can afford the bearings. Thats like building a band new engine and using old piston rings.
The governer re-cal kit is the same one I use, but is sold by Superior (probably manufactured by the same company).
Whatever car you get the brakes off of, get the prop valve as well.
Old May 25, 2003 | 09:48 PM
alright, i guess ill shell out for the kit w/ the bearings
just a couple more questions..
do i need a differential cover?
and will this work for my gears? http://www.slponline.com/view_produc...RTNUMBER=63006
i cant seem to get on 700r4.com which somebody suggested when i was searchin threads. if i can get on there sometime, ill probably look for speedo gears
thanks for all the help
Old May 26, 2003 | 01:43 PM
what i meant was...
do i need a NEW differential cover? i heard they improve durability and such under strong loads, but i only have a 3.1
Old May 26, 2003 | 05:08 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Since you have a V6, and is worried about cost, I would say forget it. Use the stock one.
Old May 26, 2003 | 07:34 PM
i appreciate it
Old May 27, 2003 | 09:47 AM
82camaro's Avatar
Car: 82 camaro SC
The tranny shifts at a given rpm, regardless of rear-end ratio(your shifts will be at the same rpm, which is probably what you want). Wait on the re-calibration kit until you are sure they aren't correct. You will run slower if you shift past your engines rpm 'power band'. 3.73's will wake up that v6--have fun.
Old May 27, 2003 | 11:51 AM
another question...
im plannin on gettin a transgo rebuild/shiftkit sometime later and maybe going with full manual control with it. woudl this just destroy the purpose of a re-calibration kit?
thanks for the help
Old May 28, 2003 | 04:35 PM
another question to add on to the one i just posted...
i figured out my speedo gears and its 15 for drive and 43 or 44 for driven. im just wondering if these will work since my speedo is electric
http://www.700r4.com/catalog/catalog...BCAT&CATID=NA1
http://www.700r4.com/catalog/catalog...BCAT&CATID=NA2
will they work?
Old May 30, 2003 | 04:09 PM
anyone?
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
