old 350 trans
Old Jun 8, 2003 | 05:51 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
old 350 trans
i just did a motor and trans swap a few days ago and i switched from the 700r4 trans to the 350 that was on the motor i swapped in. the shifter linkage and other things hooked up fine. the problem is my drive shaft is too short and the driveshaft off of the chevelle that had the trans in it is too long. the guy said its a 75 chevelle(did they make those in that year?). my question is, could i find a driveshaft just long enough at a junkyard? or is there some kinda extension i could put on the trans to make my old driveshaft fit? he said something about a longer yoke. where could i get one of these? and how much?
Old Jun 8, 2003 | 08:15 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
comments? help? anyone?
Old Jun 8, 2003 | 08:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take the Chevelle one to a drive shaft shop and have it shortened.
If you can't find a shop listed that way in your area, call around to places that work on big trucks (18-wheelers and bigger).
Old Jun 8, 2003 | 08:30 PM
25thanniversZ's Avatar
or find an early thrd gen with the th 200 and rob the shaft outa it
Old Jun 9, 2003 | 12:02 AM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Why wouldnt you just take the tail off of the 700r4 and put it onto the th350 and use the 700r4's driveshaft....
Old Jun 9, 2003 | 12:38 AM
differant lengths and youve then got the speedo problem
Old Jun 9, 2003 | 02:25 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
anwyay to tell if the early thirdgen has the th-200? i already tried using the tail, didnt work. thanks for the help:hail:
Old Jun 9, 2003 | 03:21 PM
3 speed non removable tailhousing
Old Jun 9, 2003 | 08:40 PM
My8T7TA's Avatar
as RBL3869 said, have it shortened. I just did the same thing to my 87 TA,,,, swapped motor and trans. from an 89 chevy mailbu. I went to a local mechanic that fixed mine. Worked great! Good Luck!
Old Jun 9, 2003 | 09:13 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
how much was it to have it shortened? money is kinda tight, really need to start saving. if i cant find one off of a th-200 trans then looks like it will have to be mechanic.
Old Jun 9, 2003 | 10:02 PM
ChellysCamaros's Avatar
I just did this swap... Had to take the driveshaft and get it shortened 3inches... which still ended up having to be shortened again another inch.. but I used a driveshaft outta 78 camaro....same place I got the donor tranny...so far only problems im hacing is the torque arm mount and the speedo is off by about 20mph... lol.. but nothin to shake a stick at... easy fix..lol.. GOOD LUCK!
Old Jun 10, 2003 | 07:02 AM
My8T7TA's Avatar
It cost me $50 but I know the mechanic pretty well and hes done most of my work. Dont know if that made a difference or not but from what I have heard its between there and $75 around where I live.
Old Jun 10, 2003 | 05:49 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
75 huh? ouch looks like i better pray to some junkyard gods that some place has one i can get. thanks all for the input, should be fixin the prob soon if i can find one, if not, wont be till i get paid. o well, ive lived without my car for a year a week or so wont hurt me:lala:
Old Jun 10, 2003 | 06:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well, considering that if the junkyard knows what it is, that 200C shaft will cost you $100 or more, I'd say $75 is cheap.
That's why it's the best thing to do. Skip all that other monkey-motion and go directly to the solution.
Old Jul 24, 2003 | 10:05 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
longtail tranny in chevelle is not correct for it, is out of truck or old full size car.
you need shorty tranny or find a local welder guy to cut down your shaft for about 30 bucks tops.
Old Jul 24, 2003 | 09:04 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Go to Car-parts.com directory for your state...Look under 82 Automatic Driveshaft, There is 3 available in Virginia
theshackle
Sep 17, 2020 08:26 AM
camaro71633
Sep 1, 2015 10:24 AM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
milk
Aug 10, 2015 06:26 PM
