transmission gear belts HELP!!!!!
Guest
Posts: n/a
i don't know what is wrong with the transmission. it is like 2nd and 3rd is just not there it won't go above 45 mph and i have put all kinds of fluids and cleaners but nothing is happening to it to fix it i need help it is a 87 ta transmission and i don't know if it is the fact that i have a afert stock engine v8 or what. if you have any answers to my problem let me know thanks.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What color is the trans fluid? does it smell burnt? did you notice anything leading up to this problem or did it just stop shifting one day when ya went to drive it? if you have/plan any sort of major mods you may want to consider switching to a th-350 or a 400 anyway.. the 700's arnt the strongest trannys known to man.....
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
do a search on 'TV cable adjustment'. There are lots of threads on how to adjust it. Theres a good pic of what the tv cable and racheting mechanism looks like in the tech articles, but the adjustment method there is incorrect.
i would look elsewhere.. a tv cable is very unlikely as your trans would still be able to shift even if it wasnt hooked up.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
