what do the V6s and V8s have in common?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
reason i ask is this:
i was at several wrecking yards today looking for somthing, but i cant resist looking in every 3rdgen i come across.
i noticed that out of all the 3rdgens i see the V6 ones are almost untouched in the drivetrain..
i have a V8 but im wondering:
i know the bell housing is diffrent, but is the manual tranny the same?
are the clutch/brake pedals the same as the V8 pedals?
and non drivetrain related:
will a AC compressor from a V6 hook up to my V8s brackets?
clutch/brake pedals the same.
Rear end, the same although V6's usually didn't get any of the good options
Tranny's different, although some reported getting the T5 to work somehow with a V8.
Compressor...I dont' think so, but I've been wrong twice before.
Hey Ovrclck350... fooling people into clicking on your link so you can get more "thugs" is pretty stupid. It's no better then good old misleading spam techniques. I would definately not expect this from a moderator.
You're the one who clicked, don't blame me for you curiousity getting the best of you. If I had REALLY wanted to be tricky, I'd have renamed the link to "Pics of my Car" or something. I have nothing to hide though.
And since when does Moderator mean that I'm different than anyone else? Basically all Moderator means is that in my forum I can lock threads and ban troublemakers. Nothing special.
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
anyway... travis.... the rear axles are the same, but most v6 rears came with drums... you can usually find a 3.42 rear if it's a v6/5 speed.
transmissions, v6 auto can't be used because of the bolt pattern of the case being different. you can use a v6 t5, but you'll need a clutch disc from a v6, as the splines are different. the v6 clutch disc is about 9.5" as opposed to the 10.5" clutch that the v8 trannies got.
the v6 t5 will physically bolt up, but i just don't like the idea of running that small of a clutch on a v8. i have this set up in my red camaro, and i hate it. when i'm able to get another transmission setup, i'm thinking a g-force or a tremec.
Car: 91 Camaro Vert
Originally posted by Air_Adam
Who cares?
Who cares?
lol, you obviously arnt paying attention, so i'll type slower for you
v6 cars.
people dont care to strip them in the yards.
therefore, they are in decient shape.
i want to do a manual conversion on my vert.
i wanted to know if i could take the tranny from the v6s and have it work.
however, it wont
with the way i drive, i would fry the v6 clutch behind the v8.also, im going to swipe a v6 air compressor since im a cheap bastard and they're only $5
Originally posted by robertg
why bitch about it here? you clicked it, you should have known when something says "click here" that it might not be a good idea to click it, especially if you're at work.
Car: 91 Camaro Vert
Why bitch about it ? Because it's ****ing stupid! Especially when a moderator does it. A moderator who's supposed to set an example for all other users. Would you like it if I got on a bunch of sites and started putting ads in my signature for you to click on so you can make me money ? You'd probably be pissed off too. But nooooo, you have to take his side, because you ****** moderators have to side with each other, even when you KNOW what he's doing is wrong.
and hell, billy even AIMed it to me one day.
just pay attention to what you click on. just cause it says click here on the internet, doesnt mean you should.
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
It says the website on the click here link...Your fault for not payin attention...Geez dont $hit a Brick!
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Car: 2000 astro
Engine: 4.3
Transmission: A4
[B]Why bitch about it ? Because it's ****ing stupid! Especially when a moderator does it. A moderator who's supposed to set an example for all other users.
you don't get it, do you? about the only thing we're here to do is make sure the board is run smoothly.
Would you like it if I got on a bunch of sites and started putting ads in my signature for you to click on so you can make me money? You'd probably be pissed off too.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Skatepunk60, will it fit the shaft? It may be worth trying if you can get the disc its self just to mess around with. you could buy v6 t-5s and just have fun beating the hell out of them with out any worries.
Royal_Z
Sep 30, 2015 08:45 PM
