t56 2pc seal flywheel # ?
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well, I went to the machine shop (really one I was told was good(sure
) any way I tried to tell the what I needed and the kid just looked confused. so I dummied it up for him and said I was just putting a older 2pc 350 in a 96 camaro lt1 with a 6-speed. holly cow I told him lt1 now he keeps looking for this setup but, does not listen when I tell him it does not need to say lt1.
I mean what the #^%^! well then I say to him can you drill the stock flywheel for the old bolt pattern. and I ask him if it will be too weak. he starts telling me it will be weaker (
I thought that hence the question. will it be too weak) I don't think I will ever go back there again I will just go to the machine shop I usually go to he may take a long time but, he really knows his stuff and I know he can find the flywheel part number
I thought that hence the question. will it be too weak) I don't think I will ever go back there again I will just go to the machine shop I usually go to he may take a long time but, he really knows his stuff and I know he can find the flywheel part number Supreme Member
Car: 4
Engine: 6
Transmission: 5
Visit www.centerforce.com and get the part #, it's so easy even I can find it, then check Summit, Jeg's and your local speed shop.
Engine: ls1, LB9
I guess I am slow, I don't see which one I need. the book he had showed what I thought might be the right one but I don't see it here. his book said something like (93-97 camaro w/6spd 2pc seal) he would not let me get a good look though.
this is the center force list.
Below is the list of available domestic flywheel applications for CHEVROLET.
Make Application Ring Gear Teeth Counter Balance Steel Wt. Steel Part # Alum. Part # Alum. Wt. Clutch Pattern Ring Gear O.D. Status
CHEVROLET 1986 & UP 305, 350 ENG. 153 YES 30.1 700170
$322.95 900170
$706.95 13.6 2 12.835
CHEVROLET 1986 & UP 305, 350 ENG. 168 YES 35.7 700160
$313.95 900160
$748.95 16.1 2,3 14.096
CHEVROLET 1997-02 LS1 & LS6 ENG. 168 NO 29.7 700142
$327.95 - - O.E. 14.096
CHEVROLET 4.3L 262 V-6 ENG. 168 YES 35.7 700160
$313.95 900160
CHEVROLET 4.3L 262 V-6 ENG. 153 YES 30.1 700170
$322.95 900170
CHEVROLET 400 ENG. 153 YES 29.9 700102
$351.95 900102
$690.95 13.6 2 12.835
CHEVROLET 400 ENG. 168 YES 37.3 700190
$361.95 - - 2,3 14.096
CHEVROLET 400 ENG. 168 YES 36.1 700180
$359.95 900180
$784.95 18 2,3 14.096
CHEVROLET 454 ENG. TO-1990 2pc. REAR MAIN SEAL 168 YES 35.9 700140
$334.95 900140
$716.95 16 2,3 14.096
CHEVROLET 454 ENG. TO-1990 2pc. REAR MAIN SEAL 168 YES 37.3 700150
CHEVROLET 454, 502 ( HO ENG. ) 91 & UP FORGED CRANK 168 YES 36.3 700148
$309.95 - - 2,3 14.096
CHEVROLET 454, ENG. 1991 & UP CAST CRANK SHAFT 168 YES 36.3 700145
CHEVROLET ALL V-8 ENG.TO-1985 EXC. 400/454 153 NO 30.2 700100
$304.95 900100
$722.95 16 2 12.835
CHEVROLET ALL V-8 ENG.TO-1985 EXC. 400/454 168 NO 36.3 700120
$310.95 900120
$700.95 15.6 2,3 14.096
CHEVROLET ALL V-8 ENG.TO-1985 EXC. 400/454 153 NO 41.6 700110
$353.95 - - 2 12.835
CHEVROLET ALL V-8 ENG.TO-1985 EXC. 400/454 168 NO 37.7 700130
$346.95 - - 2,3 14.096
CHEVROLET CAMARO w/6 SPD. 1993 - 97 LT-1 & LT-4 153 YES 35.2 700177
$446.95 - - 2 12.835
CHEVROLET CAMARO w/6 SPD. 1993 - 97 w/ENG. MFG. 153 YES 35.2 700173
$454.95 - - 2 12.835
CHEVROLET CAMARO w/6 SPD. 1993 - 97 w/ENG. MFG. 153 NO 35.5 700107
$442.95 - - 2 12.835
CHEVROLET CORVETTE w/6 SPD 1989 - 96 L98 , LT1 ENG. 153 YES 33.7 700175
$432.95 - - 2 12.835
CHEVROLET CORVETTE w/6 SPD 1989 - 96 w/ENG. MFG. 153 YES 33.2 700174
CHEVROLET CORVETTE w/6 SPD. 1989 - 96 w/ENG. MFG. 153 NO 33.1 700105
$453.95 - - 2 12.835
$322.95 900170
$313.95 900160
$313.95 900160
$322.95 900170
$351.95 900102
$359.95 900180
$334.95 900140
$304.95 900100
$722.95 16 2 12.835
$310.95 900120
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
go back to the machine shop. avoid the kid, and find the old guy that actually does the work.
every good machinest ive ever seen/heard of is atleast 35.... i think thats because it takes about 15 years to just get good.
Car: 4
Engine: 6
Transmission: 5
I went and looked at their page... they've changed it since Ilast looked at it.... it's wacked
Should say "w/eng 85-bacK" or words to that effect
Engine: ls1, LB9
I stopped by my normal machine shop and like I thought they did not want to do the whole bolt pattern thing. they said it "could" hold but, those cast flywheels have a habbit of blowing up when beat on too much. they went on further saying that for the money it is a real good Idea to just buy the steel one. you know the funny thing is they are a smaller shop and in a real small town but, he knew right away what I was asking and knew just how the clutch works. If I did not know any better I would have thought he just was looking at one before I came in. he is going to see if he can get me a better price than summit or jegs can.
monte87cortez
Sep 26, 2015 08:10 PM
Dragonsys
Sep 25, 2015 03:51 PM
