Replacing 700R4 with TH350 questions
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I am getting a TH350 built up to replace my bad 700R4 in my 86 Iroc. I got the TH350 with the 9" tail shaft. Will the front yoke on my current driveshaft fit the TH350 and will I have to lenghten or shorten my driveshaft?
Transmission: 4L80E/4L80E
The driveshaft for a 9" tailshaft TH350 will be the same length as for a TH700.
Mounting the tranny to the crossmember may be a different issue.
Car: 1986 Iroc
Thanks for the quick replies guys. I am glad to hear the driveshaft will fit and be the right length. I should be able to work around the crossmember mount point alright. The TH350 and 3500 stall should be ready in a week and then I will take my car to the shop for the swap. I am trying to get all my ducks in a row before the car goes in. Thanks again
Car: 1986 Iroc
I ordered the B&M TH350 swap kit. It should be here by Friday. I have read others have used this kit and it worked out alright.
Iroc8t8
May 4, 2026 08:09 PM
