dumb questoin but...
Old Jul 26, 2003 | 02:38 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
i know this happens to all of us but if your tranny mount breaks will you lose power
Old Jul 26, 2003 | 04:50 PM
ede's Avatar
ede
i'll say no, but you won't be applying the power you do have in the most efficent fashion since the rear is now rotating more because the trans is lifting because of the broken mount.
Old Jul 26, 2003 | 05:14 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If you know your tranny mount is broken, just replace it and then you will not have to worry about a power loss.
Old Jul 26, 2003 | 06:23 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yep and then you wont have to replace tranny thanks to bellhousing busting because of that bad mount.
Old Jul 26, 2003 | 11:00 PM
Car: 89 trans am
Engine: 355
well i know it's the problem and i have an extra tranny mount i am installing it tomorrow but it just seems like it's got like no power.
do you have to take the crossmember off to replace the tranny mount? or just lower it alittle and take the bolts out that hold the tranny mount or let me know what you guys think is the easiest
Old Jul 26, 2003 | 11:57 PM
Rage13's Avatar
Car: 89 Firebird
mite as well just take it off.. only like 4 bolts anyway
Old Jul 27, 2003 | 02:11 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
I agree....it's not a big deal, and it makes replacing the mount easier. While it's out you can carve off all the sludge buildup on it and give it a good cleaning and a fresh coat of paint!
Old Jul 27, 2003 | 06:12 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
two bolts and one nut, done, metric, 5/8 will fit but sloppy, 14 or 15mm is actual size i forgot which cuz i used neither i just used 5/8, it worked for me the other day installing the th350 in plac eof thm200c
theres plenty of room to get at the bolts and nut under there, block the car up real well and go for it, wont take long, just is grimey messy under there
good luck
Old Jul 27, 2003 | 11:53 PM
Car: 89 trans am
Engine: 355
thanks guys
Rally Smith
Sep 14, 2015 06:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
elevario
Car Audio
Oct 2, 2001 06:49 PM
89PFB
Apr 25, 2001 07:53 PM
AcSeb
Oct 14, 2000 12:13 AM
