Top Speeds w/ 700r4
Old Sep 30, 2003 | 08:45 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Top Speeds w/ 700r4
Alright 3 questions:
1) What does your car max out at? (700r4's only!)
-list auto or manual
-list engine size and type
-list rear end ratio
-list if it was in 3rd or OD (upshift kit)
-don't list unless you actually had it COMPLETELY maxed out (no BS......f-bodies don't go 200mph)
example:
This is me: maxed out at 131mph (GPS certified)
-auto
-350 tpi
-2.73 rear
-in 3rd,....no upshift
2) Is anyone running an upshift kit? How hard are these to install? Do any shift kits come with an upshift built into it?
3) Any guesses on what'd I'd hit with an upshift kit? I have 3" exhaust, cam, headers, chip, etc...
thanks,
Old Sep 30, 2003 | 09:14 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Opps,....forgot 2 things:
1) Please also include year and model and general degree of modification
-car above was an 88 Trans AM
-mild-to heavy moddified
2) forgot about my old Formula
maxed out at 115-117 in my 1989 Formula (not gps certified)
auto
305 tbi
2.xx?
3rd
stock
Old Sep 30, 2003 | 10:46 AM
Morley's Avatar
Do some reading on the net on this subject.
CC had a stock 90 IROC up to 144 mph on a 3 mile course.
Old Sep 30, 2003 | 11:54 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
1985 IROC Z, 305 TPI
Cat/Exhaust and free mods. STOCK MOTOR.
145 MPH Speedo that seemed accurate when comparing to other vehicles, the needle went well past the 145 mark.
3.23 Gears
Auto
OD w/o Upshift
Old Sep 30, 2003 | 12:06 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
90 formula 350 TPI (OEM 700r4) when car was stock (except new fuel injectors)
3.27 gears
stock tire ratio
stock 700-r4
Did 130+ mph in 3rd gear.
Lifted let it shift to OD then I put it about 1/2 back down... maxed 145 speedo and dropped around 1 inch to 1 1/2 below that. I lifted then I think I was around 4500 rpms or so.
Old Oct 1, 2003 | 09:49 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
120 in second gear 700r4 and 2:73
Old Oct 1, 2003 | 10:34 PM
Engine: 383 SBC
I can the 4500 rpms through the MPH generator tech equations and I got 155 mph. It still had more left but it was becoming a snail in acceleration... I haven't tried it since I got a feeling my 9.5 inch ACT stall will slip a little bit till I get going fairly decent.
Old Oct 2, 2003 | 01:20 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
88 Firebird Formula
305TPI
No mods, car is bone stock (except for the ram air hood)
3.23 gears
Tranny will upshift to 4th at WOT.
Got it up to 135mph 2 weeks ago, it just took awhile to get there.
I was running against a friend that has an 88 GTA 305TPI 5 speed with headers and catback.
Old Oct 3, 2003 | 05:18 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Re: Top Speeds w/ 700r4
That quote is completley false. I have video footage of one doing 215mph. Banks had an 82 that would do 220mph also.
To answer your question though
155mph (Still pulling)
2.73
lifted off to shift into 4th
Old Oct 3, 2003 | 05:51 PM
Zepher's Avatar
They go 200+ with enough power,
Hotrodboba400
Dec 10, 2019 07:07 PM
Vojtush31
Oct 11, 2015 01:07 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
someone972
Aug 30, 2015 12:52 AM
