rough shifting (automatic)
Old Oct 26, 2003 | 10:29 PM
JUnderscore's Avatar
Car: 1986 Firebird
Engine: 2.8L MPFI (LB8)
'86 Firebird
I wondered if someone could tell me what might cause my car to jerk/jolt some when I shift (auto transmission).
There's no jerk when I shift from overdrive to neutral OR reverse to neutral. But between forward gears and shifting out of park causes a bit of a jerk.
Oh. And I'm talking about experiencing the jolt while stopped.
Had U-Joints checked a couple times. That's all.
Thanks. From someone with no transmission knowledge.
J_
Old Oct 27, 2003 | 04:25 AM
Pro Built Automatics's Avatar
If you are talking about the park/neutral to any forward gear engagement?, then it is because there is not an accumulator. In 1987 they introduced this. A low idle helps here, or a higher stall torque converter helps.
Old Oct 27, 2003 | 04:54 AM
Nozzghoull's Avatar
Car: 86 TA
Engine: 383 Stroker
atten:Probuilt
Hey Probuilt, can an accumulator be added???
Old Oct 27, 2003 | 02:41 PM
No.
Old Oct 27, 2003 | 03:49 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Is he talking about the When you shift out of park when the RPMS drop to 400 and then surge back up?
Old Oct 27, 2003 | 07:58 PM
Car: 1986 Firebird
Well, this is not something that my car has always done. That's why I wondered if there was something out of adjustment.
After I posted initially, I read that it could be from the tranny fluid being cold. Anyone agree?
No tachometer in my 'Bird.
J_
Old Oct 29, 2003 | 08:23 PM
speedfreak918's Avatar
I have a 92 R/S that is doing the same thing. When I shift it from park to drive it has about a 2-3 second delay then clunks into gear. This is the only problem with this tranny, and it is the original tranny. Accumulator? How to fix it? Thanks.
Old Oct 29, 2003 | 10:04 PM
Found out what it is
One the trannys cold takes a sec to Pressurize and two i pluged my EGR and it stoped doing it
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
amcnellis
Sep 16, 2015 04:16 PM
ynk1121
Sep 12, 2015 12:27 AM
