how do you add trans fluid?
Old Oct 29, 2003 | 12:05 PM
ririe's Avatar
I own a 1987 Chevy Camaro V6. The car has an automatic transmission and i checked the transmission fluid after it has been driven, in park while idling and it said it said "Add one pint". my question is where do i add more transmission fluid? Thanks a lot.
Old Oct 29, 2003 | 12:06 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you pour it right down the dipstick tube.
Old Oct 29, 2003 | 01:51 PM
ririe's Avatar
past the chekered part of the dipstick is considered full right?
Old Oct 29, 2003 | 02:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
DONT overfill it. it will cause more damage then good..... and its hard to take fluid out without just draining the whole thing....
i donno what the stick looks like off the top of my head....
Old Oct 29, 2003 | 02:18 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I believe the dipstick works the same way as the oil it should be fairly self explanitory, I think you want to check it when the tranny is warm, and my mechanic told me to shift through P N O/D D 2 1 a few times before checking it. I wouldn't add a whole quart unless it was fairly low, its alot easier to add more than it is to take it out.
Old Oct 29, 2003 | 02:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
some have the "low add me" range in crosshatch
others have the entire range in crosshatch...
i donno what yours is. *shrug* anyone?
Old Oct 29, 2003 | 02:27 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Read what is says on the stick?
Old Oct 29, 2003 | 09:07 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Isn't the car suppose to be idling too while you check it?
Old Oct 29, 2003 | 09:34 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
yeah that is the jist of it chris. the two manuals i have used in the past haynes and chiltons say that the tranny/engine should be warm opperating temp and idling while checking fluid level.
Old Oct 29, 2003 | 10:43 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Ive always woundered... What happens when you over fill it I always kinda run my tranny "lean(never toped off)" if you will
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
killer777
Aug 8, 2015 02:47 PM
Leggman1
Aug 6, 2015 04:15 AM
