3.73 Help NEEDED
Old Nov 6, 2003 | 09:55 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
3.73 Help NEEDED
i have an 84 stock TA with 3.73 (one wheel wonder) gears in it. i need to know if i can just buy new gears to get a 3.73 posi and if i can what's the site that has them.
Old Nov 6, 2003 | 10:05 PM
chio987's Avatar
Engine: 305 4bbl HO
also i think it is a 7.5" 26 Spline but am not 100% sure nor am i sure what that means. so if someone could explain it that would be very helpful. if that is what it is is this what i need summit P# 109-542044
Old Nov 7, 2003 | 01:51 PM
chio987's Avatar
Engine: 305 4bbl HO
doesn't anyone know anything? please help me out here
Old Nov 7, 2003 | 06:15 PM
ede's Avatar
ede
26 spline axles in 84. you don't need another gear set to make it a posi, you need a new carrier, you can reuse your old gear set
Old Nov 8, 2003 | 07:52 PM
chio987's Avatar
Engine: 305 4bbl HO
hey, EDE where would I get a new carrier? What site?
Old Nov 9, 2003 | 09:52 PM
chio987's Avatar
Engine: 305 4bbl HO
does anybody else know where i can get a new carrier that EDE is talking about? and what i need to look for when getting one as well as where.
Old Nov 9, 2003 | 10:10 PM
bohn333's Avatar
Car: 1987 Trans am
You can get a carrier from auburn, eaton or a variety of places. I would look on e-bay for a 26 spline 3 series carrier. You can go with the zexel takeoff from SLP for $99 but you would have to swap over 28 spline axles. Which would be a good thing anyways.
Old Nov 10, 2003 | 10:56 AM
chio987's Avatar
Engine: 305 4bbl HO
i thank u for your help but the last thing i am wondering is what is a carrier?
Old Nov 10, 2003 | 06:46 PM
bohn333's Avatar
Car: 1987 Trans am
It what the ring gear bolts to.
Old Nov 10, 2003 | 08:16 PM
chio987's Avatar
Engine: 305 4bbl HO
i just found something out tonight. my boss has a 99 TA that had 3.42 posi but he got new 3.73. he sed he still had all the stuff to make my car posi, but can i still use my 3.73 gears? and i bet i would half to get new 28 spline axles too right? i i do, what would they run. (or what specs do i need other than the 28 spline)
Old Nov 13, 2003 | 11:07 AM
chio987's Avatar
Engine: 305 4bbl HO
doesn't anybody know if the 4th gen gears will work in my car? and if it will take my 3.73 gears
Old Nov 13, 2003 | 11:42 AM
ede's Avatar
ede
gear set from a 4th gen will fit and work, just make sure the carrier series is the same.
Old Nov 13, 2003 | 08:22 PM
chio987's Avatar
Engine: 305 4bbl HO
ok, mabye i need to ask in different words. do i need to change anything on my 84 TA to make his 99 TA rear work in my car? mine right now is 3.73 open rear end, his was a 3.42 posi. i want to keep the 3.73 gears from mine but use his old parts to make it posi. so once more. do i need to change or get anything new or different to do this? keep in mind i don't know ANYTHING about rear ends so advising me to make sure the carrier series is the same is pointless bcuz i don't know how to check and what i have? right now with this carrier stuff i'm VERY
Old Nov 13, 2003 | 08:35 PM
chio987's Avatar
Engine: 305 4bbl HO
this is all i have fom my RPO
Y06 : RING GEAR, 9.50 IN., SAGINAW, (S.P 0.)
GT4 : AXLE REAR, 3.73 RATIO
and it sed it was unable to locate codes: 17C E6N WS5 WY6 and i'm about 99.9% sure i type them in right so if anyone knows what they mean, please let me know. (and i'm sry this was sorta of the subject)
Old Nov 13, 2003 | 08:47 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i dont think youll be able to use 4th gen 28 spline axels because theyre 2" longer i believe. youd need axels from a 88?-92
Old Nov 13, 2003 | 10:14 PM
chio987's Avatar
Engine: 305 4bbl HO
i figured that i would need to up grade to some 28 spline axels ffrom a later 3rd gen, (i'm not sure but i thought 84 was the last time the 26 spline was used with TA's) but what about everything else, like the carrier and using my 3.73 gears instead of his 3.42?
Old Nov 13, 2003 | 10:35 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
3.08 and lower is a 2 series carrier, 3.23 and up is 3 series, so your gears will work.
Old Nov 14, 2003 | 09:58 AM
chio987's Avatar
Engine: 305 4bbl HO
thanks for all your help KagA152, i know i'll need some 28 spline axels so can u advice me on where to get some cheap ones? and i need ones from a late 80's, right?
Old Nov 14, 2003 | 11:36 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Junk yard is the only cheap place to get those thirdgen 28 spline axles. Otherwise you can get any length/size axle (for the most part) that you can dream up from places like Strange and Moser. A set for something like a C-clip 10 bolt will run you about $260 shipped to your door.
The spline of the carrier and the axles needs to match. No mismatching. Ever, period.
Ede covered this, but once again, any 7 1/2" gear set will work on any carrier - posi or otherwise. No need to change gears to go from non-posi to posi.
Right now you have 26 spline axles and a 26 spline open carrier. Most aftermarket carriers are 28 spline for the 7 1/2" 10 bolt but I know the Auburn can be had in 26 spline. The cheapest way for you to get a "posi" is to buy a Powertrax or a minispool. The minispool is a bad move on the street as it will mechanically lock the axles together and eventually something will break. Not to mention it makes the car drive like poop and push the front end all over the place. The Powertrax is a bolt in locker assembly that replaces the spider gears inside your existing open carrier. They will still allow differentiation of the axle but will lock the axles together when you are accelerating in a straight (or fairly straight) line and thus spin both tires (given there is adequate power to do so).
How much money have you set aside for the budget for this project and would it be an accurate assumption to assume you will be paying someone else to do any mechanical work on this project?
All comes down to money really.......
hectre13
Dec 11, 2023 08:14 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
