Is this an easy FIX??
Old Nov 16, 2003 | 07:41 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I was putting on the sending unit for the Autometer electric speedo when all of a sudden my takeoff for the speedometer on my trans broke off! It was not even put on there all the way. I was not done screwing it on and the casing with the threads on it broke right off of the trans. Now, is this going to cost me a new trans, or would it be fixable? Has anyone ever seen this before? It is a 700r4. Please, any help would be great. thanks
Old Nov 16, 2003 | 11:27 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
N E 1?? Also, maybe a price that i could expect too? Don't want to get ripped off! Thanks again
Old Nov 25, 2003 | 09:46 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Does anyone have any input? Ever hear of this before? Thanks
Old Nov 26, 2003 | 12:35 PM
Nordbert's Avatar
Write down the numbers which are cast on the face of the
adapter and call a local tranny shop. They probably have a used one or can order one for you. You might have to remove the driveshaft and tailhousing to get the old one out of the housing if there is a lot of corrosion around the adapter.
Old Nov 26, 2003 | 01:57 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
So you have heard of this before? I know i have never heard of it happening. I'm just looking at what i should expect for a repair on it. thanks
Old Nov 27, 2003 | 11:20 AM
Morley's Avatar
Is this the part that broke? If so, it is between $30-$60 for a new one. Don't forget a new O ring for it and a new seal for the speedo gear. you can buy them here http://www.transmissioncenter.net/sp...n_______va.htm
Old Aug 1, 2004 | 11:45 AM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
I just had exactly the same problem, seems the inside diameter of the Autometer sender is just slightly smaller than the outside diameter of the cable hook-up.
How did you work around this problem?
Old Aug 5, 2004 | 05:30 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
LOL, my money pit is still sitting in the driveway! The motor runs excellent, but the car does not move. I have not seriously worked on it in weeks. Before I drive it I need to hook up my guages and shifter. Thats pretty much it. Call it laziness, call it being too damn busy with a ft job, school since Jan. and a ft girlfriend. Not to mention everytime I have gone out there, I am either missing a part, or something will break or not work. I plan on getting it back to the shop who did my trans. Its a few miles from here, and from what I can tell the trans does not leak anymore. good luck
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
