Really hard neutral to drive shift
Old Nov 20, 2003 | 05:30 PM
bigj85z-28's Avatar
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
After I start the car and go through reverse, and neutral, as soon as i get into OD, its a 700r4, the car almost jumps forward, its not a high idle, idle is about 650-700. Could it be a loose tranny mount? Or a shift kit? Cause it is definantly a really firm shift. Thanks for any help.
- Justin
Old Nov 20, 2003 | 07:12 PM
Bandit5's Avatar
Sound slike you need to adjust your TV cable. There is too much pressure at idle, you need to loosen it up. Have it adjusted at a shop the right way, and have them show you how to do it.
Old Nov 21, 2003 | 07:55 AM
bigj85z-28's Avatar
Car: 79 z-28
Sounds good man. Thanks, that was just the type of answer i was lookin for, somethin thats cheap and easy.
-Justin
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
maroe624
Apr 16, 2017 08:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
