t5 VSS Plug ?
Old Nov 23, 2003 | 08:06 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
t5 VSS Plug ?
I picked up a supossed 91 TA t5. All of the casting # Point to 91, however, the VSS has a plug that is not like my auto VSS plug from 90 and the harness in the car is from a 92 t-5 and it has the same plug as my auto VSS.
I guess my question is does anyone have a vss in a t-5 that looks like the top one in the pic below? (this is the one out of the t5 I got) It does produce an ac voltage when I spin it so it seems to be working.
The bottom pic is a picture of the socket I was expecting (yes I realize it is one from auto, just using as plug in reference)
If all I have to do is change the plug end on the harness I will do that, however, I don't want to cut it up and find out that I really should have left it alone and purchsed a new VSS.
Anyone out there have some feed back?
Old Nov 23, 2003 | 09:52 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
VSS
That one is for '86-'89 the '90-'92 is different (looks like that auto one you show) yours should be 4000 pulses that one is 2000. Get the right one for your car.
Old Nov 24, 2003 | 05:26 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
thanks, Not exactly what I wanted to hear when a new one is almost $60
Old Nov 24, 2003 | 03:31 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I thought that the camaro optical VSS that were on the back of the speedo's were the 2000 ppm, where the magnetic ones on fbirds on the trany were 4000 ppm? or am I mistaken
Old Sep 18, 2022 | 05:59 AM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
Re: t5 VSS Plug ?
Any chance that you still have this vss?
wigmobile
Feb 26, 2025 02:56 PM
GTAman
Jul 3, 2024 07:29 PM
gta892000
Aug 11, 2019 11:16 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
