700r4 question
Old Nov 27, 2003 | 12:47 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
700r4 question
This question has prolly been asked before, but, Is there a way to delay the 1st to 2nd shift? If so, how? AND, Is there a way to go into overdrive at WOT? I don't want to have a custom job done, I just want to be able to take a little more advantage of the low end power of my little V6..thanx
Old Nov 28, 2003 | 06:24 AM
ede's Avatar
ede
without internal mods your only option is to manually shift
Old Nov 28, 2003 | 12:55 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
By changing the weights/springs on the governor.
Old Nov 28, 2003 | 04:37 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
change the throttle valve sleave and re-calibrate the trans governer.
Old Nov 28, 2003 | 10:54 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Re: 700r4 question
GM part #8673948 (B-Car Fix) allows a full throttle upshift into OD.
I would also install an RV stage shift kit.
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
