true or false?
Old Dec 10, 2003 | 01:56 PM
htown_89bird's Avatar
Car: 89 Formula350
true or false?
Sup 3rd genners... got a quick true or false question....
1990-1996 S-10 blazers came with 3.73 gears and can be used on 3rd gen f-body cars.
has anyone ever heard of something similar to that?
Old Dec 10, 2003 | 03:45 PM
ede's Avatar
ede
any gear set from a 7.5/7.62 ten bolt will work in thirdgens with the same rear, as will gear sets from 4th gen f bodys
Old Dec 11, 2003 | 12:21 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Note that the axle will not bolt up though. S10's/Blazers are rear leaf springs, and our cars are coil. Therefore the axles will have different spring seats. However, the gearsets will swap fine.
Old Dec 11, 2003 | 08:48 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I know this is a little off the subject, but not too much.
What is the difference between the 7.5 and the 7.62? I know the obvious difference . What I am wondering is that in catalogs they advertise some parts for 7.5/7.62... Will they interchange? And were 7.62s ever put in 3rd Gens? Thanks...
Old Dec 11, 2003 | 09:25 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
From what I understand there is no difference. GM just changed the labeling to make the depiciton more accurate. Therefore 7.5 IS 7.65
Old Dec 11, 2003 | 09:51 PM
dirtybird's Avatar
its actually 7.625
Matt
Old Dec 12, 2003 | 07:34 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
So they are the same, the parts will interchange so long as spline count and bearing size all matches...Thanks...
Obviously an S-10 won't go into a 3rd Gen without more work than it would be worth...
Old Dec 12, 2003 | 08:19 PM
Car: 89 Formula350
cool, so i can swap the gears though....
did the blazers or s-10's come with 3.73's?
if so, what year models?
Old Dec 18, 2003 | 02:17 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yes, some S-10s did come with 3.73s from the factory. Look for a 4 cylinder or small 6 cylinder 4x4. These are the most likely candidates.
Not all 7.5/7.625" 10 bolt parts interchange with ease. Early rears that use 26 spline axels won't accept 28 spline units because the carrier bores are too narrow. I hogged mine out with a boring bar and a brake hone and managed to get the 28 splines to fit, but you would have to take the carrier out of the rear. There was still plenty of material left after the machining, and I polished the bores to prevent stress risers from forming.
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
Djmathis123
Sep 8, 2015 08:42 PM
