I need a rear half shaft...
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
I was wondering if anyone knows where I can get a new halfshaft for my 85 Camaro. I am having a problem because I have the disc brake option on the rear. No one seems to have those around. So if anyone could help, I would appriciate it.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by ede
there is no half shafts in a f body. what is it you need? an axle?
do you need a axle???
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
i'll just about bet he doesn't return or reply. i do think he's found the reason half shafts for a 85 camaro are so hard to find.
Car: 1985 Z28
There is a left and a right side to the axle. I have already replaced the right side, because it was bent. Now I would like to replace the left side because it is bent as well. All I know is that it is a shaft that takes up half of the axle and both meet in the center. I am sorry if I have hurt anyones fealings by calling it what I thought it was. Nevermind.........
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Axle for a 82-88 disc brake rear (make sure it has cast iron calipers on it)
Half shafts are used in independant rear suspensions.
They were just razzing you, they didn't mean nothing by it. You're gonna have to have thick skin to hang out in here....lol!
Car: 91 Camaro Vert
lol, we're jsut jokin around, dont worry about it..
both sides are the same.... you can swap them around... so dont worry about finding a drivers side or a pass side.. they're the same
best place ive found is the junkyards... if you can pull it, you'll get it for less then $20... sometimes less then $10 if they're feelling nice... lol.
replace the wheel studs before you install it though..
Car: 1985 Z28
Thanks guys,
I was just having what you could call a rough night. But anyway, The only problem with a junkyard is that I can never find any rear disk brakes on camaros. Always drum.
Street Lethal
Apr 30, 2019 12:14 PM
ambainb
Apr 25, 2016 09:21 PM
