question for those with tranny cooler
Old Dec 30, 2003 | 05:18 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
Where did you mount it. I was going to mount mine in front of the radiator, but it uses cable tie type straps to mount it and you have to stick them through both radiators I guess. Does this seem right? where else could I mount it?
Old Dec 30, 2003 | 06:21 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I removed my AC stuff on my '87 IROCZ, with that I removed the AC condenser which was mounted on the front side of the radiator.
I mounted the tranny cooler where the condenser was, no problem mounting thru the radiator with those stick type nylon ties and pads.
Old Dec 30, 2003 | 09:35 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
I put mine on the condensor (only had to poke through one core), then when the AC stuff when in the dumpster, the cooler went on the radiator.
-Jesse
Old Dec 30, 2003 | 11:01 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres a post i put up a few days ago in the cooling board but i also have some nice shots of the trans cooler just have to scroll down the page a little bit.https://www.thirdgen.org/techbb2/sho...hreadid=216222
Old Dec 30, 2003 | 11:40 PM
joshwilson3's Avatar
Old Dec 30, 2003 | 11:47 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Normally, the cooler is in series with the radiator cooler when additional cooling capacity is desired.
Old Dec 31, 2003 | 01:22 AM
Car: '91 Formula
My cooler looks very similar to the one on the other thread. I havent hooked up the lines yet but I attached the cooler to the cross brace like you see in the one picture. This allows about 1/2" space between the cooler and the AC condensor, and I didn't have to go through both condenser and radiator. I don't know how you would only go through the condenser and get those little tie thingys on between the radiator and the condensor. I attached it with regular cable ties. They look at least as strong as the ones that came with the unit, by the way that look exactly the same as in the picture, the heads being little brown squares. I will take a picture and see what you think. The location is great, centered on the condensor, with good space between it and the condensor. The only worry is if the cable ties will be sufficient.
Old Dec 31, 2003 | 05:11 AM
ede's Avatar
ede
i have a dual permacool cooler with fan, oil and trans cooler. mine is mounted in front of the radiator. i had to make some brackets to bolt it to.
Old Dec 31, 2003 | 09:26 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
My trans cooler is mounted on the brace for the nose of the car. I didn't want it too close to the condenser because I didn't want to block cool air to any part of the condensor/radiator. I also hard-lined it instead of using the rubber hoses.
Old Dec 31, 2003 | 11:31 AM
oldblueZ's Avatar
Car: 85 Z28
I had to have someone hold the radiator out of the way while I put the ties through the condensor. I would have just gone through both, but I got too frustrated with it and did it my way.
-Jesse
Old Jan 1, 2004 | 02:49 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I'm looking at buying a trans cooler but I looked at my radiator and there doesnt look like enough room to mount it between the fans and the radiator. Any ideas?
Old Jan 1, 2004 | 04:42 PM
JMatlock88's Avatar
Car: 1991 Formula
Put it in front of the radiator.
spaigo
Aug 21, 2015 07:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:52 PM
