How long does my Tranny have left to live?
Old Jan 12, 2004 | 06:12 AM
joshwilson3's Avatar
Old Jan 13, 2004 | 01:21 AM
Old Jan 13, 2004 | 01:35 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I don't think you're adjusting it right, or I'm having trouble understanding what you've been doing.
Press the button and slide the cable guide in until it is all the way in. Now let go of the button and floor the throttle. It is now adjusted. Anything other than this type of automatic adjustment will result in wierd shifting.
Old Jan 13, 2004 | 02:26 AM
Old Jan 13, 2004 | 02:34 AM
Follow the instructions I gave you and see if it improves the situation.
Old Jan 13, 2004 | 03:21 AM
Old Jan 13, 2004 | 06:14 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Not saying this is the case but might be a good idea to jack up the rear and check out the driveshaft yoke, make sure the caps and u-bolts are on snug and have no play, if its vibrating pretty bad, i'd have a look at that to make sure that isn't contributing to your problem.
Old Jan 13, 2004 | 01:57 PM
The shuddering sounds like a torque converter that is failing to unlock. This happens, especially on higher mileage units. I would try unplugging the wiring harness from the trans and see if the problem persists.
Definately check your entire driveline for slop (pinion, yokes, u-joints, extension housing bushings). Go over the suspension too.
Old Jan 14, 2004 | 12:53 AM
1992 Trans Am
May 10, 2023 07:19 PM
usafirebird
Exterior Parts for Sale
Oct 19, 2017 02:00 PM
Scamo-2.8
May 20, 2016 07:01 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bdads
Aug 24, 2015 06:01 PM
