70 z28 rear
Car: 82z28
Engine: 406
Transmission: th350
70 z28 rear
a friend of mine has a 3.08 rear end from a 70 z28 and i was wondering if it will fit in my car. I heard i rear with a 3.08 carrier to fit 3.73 gears.
are the rear ends the same size?
Car: 82z28
Engine: 406
Transmission: th350
that was simple enough, but just out of curiousity and the quest for futher knowledge is the 70 rear-end wider or shorter?
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
this rear end will fit under your car you will cut and reweld mounting pearches from your original rear and purchase a brace that mounts to the housing just like the 12bolt conversion,i have one in my 83z,has been stout enough with my old big block z runnin 10.60s w/1.48 60' times, 11 yrs,now its in a small block z i am sure my 350 will NEVER see the power of the ratt!!!!!!!!i can e-mail you the pics of the bracket,very basic...the 8.2 and 8.5 look similar but i would use the 8.5 from 74-81f-body......
Car: 82z28
Engine: 406
Transmission: th350
can someone give me the measurement from backing plate to backing plate on my car so i can send her the measurement and then see what she has to say? id go out and measure but theres about 3-4 inches of snow on the ground
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
3.08 uses a different carrier than the 3.73s (2 series vs 3 series).
Is the rear a 12-bolt or a 10-bolt?
Car: 82z28
Engine: 406
Transmission: th350
dont know
its a 3.08 rear from a 70 z/28 i belive its original but not positive
my rear is a 2.73
....know the bp-bp width on my car?
my rear is a 2.73
Count up the bolts that hold the cover on the back of the rear.
Not 100% sure of the width. Look around on the net. I'm sure you'll find it.
Car: `86 SS / `87 SS
On 8.5" diffs, the 2.73 and higher gears use a 3 series carrier. 2.56 and lower is a 2 series. I don't know if the 8.2" that would be in a 70 Camaro follows that case break.
Car: 88 Camaro
Engine: L98 350
Do you have any idea what a 70Z 12 bolt rear end is worth these days? Only year for the big diff in the second gen camaros. Worth a fortune. Don't cut it up.
$650-$900 depending on who buys it. You may see them go for more than that on eBay, but those are crackhead prices. Half of those sales don't even end up going through once people find out how expensive it is to ship a rear.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
An original '70 Z/28 rear won't have 3.08 gears unless they were installed later. On the Z/28, you could only get either 3.73 gears or 4.11 gears.
Some other '70 Camaro model could have the 3.08, but not a Z/28.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
