will not stop leaking!!!!
Old Jan 20, 2004 | 12:47 PM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
Warnning kinda long.
Ok my tranny started leaking on tuesday(1-13-04) so on saturday i changed the oil and pan gasket and filter. i was thinkin it was the gasket. so sunday it was still leaking and i checked it it was still full so ok its still running off the tranny but yesterday i left work big puddle over my car get out and look and it was tranny fluid. go home check and it is still full. today on my way to work i notice smog coming from my car so i roll down the window smells like ATF so it in the parking lot look unfer my car and puddle and its leaking from the insection cover it looks like. my tranny has 170k and never rebuilt. so any help on why it would be leaking i was told it maybe coming from the front seal or the over flow but if its from the over flow is there something wrong with it to make pressure to make it come out?
Old Jan 20, 2004 | 01:57 PM
Car: 1992 Firebird
anything????
Old Jan 20, 2004 | 04:53 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
sound to me like a front seal. I had that same problem w/ my 91 rs.
Old Jan 21, 2004 | 03:06 PM
Car: 1992 Firebird
i checked the front seal and it was dry and its not leaskin from the out put shaft or the sinding and return lines for the tranny cooler or the dip stick so i have no clue.
Old Jan 22, 2004 | 09:35 AM
Wildebird's Avatar
Tranny Leak
I had a similar problem with mine. It leaked for a while, tried pushing out the pan bolt holes and everything. Finaly ended up just buying an aluminum pan and it fixed it. Thants my 2 cents. I know they are a little expensive but.....it fixed the problem.
Old Jan 22, 2004 | 11:50 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I don't know if the 700r4 has the same dipstick setup as my TH350 but the "tophat" shaped seal the dipstick is pushed into was split.I also thought it was the pan gasket and changed it.I was puzzled when I changed it again and it was still leaking.Problem was it was running down and along the gasket line.Hope you get it sorted.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
85 Jimmy
Sep 30, 2015 07:56 AM
84redta
Sep 19, 2015 09:58 AM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
