Difference between LO3 & LB9 T5's
Old Jan 24, 2004 | 05:26 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
Is there any difference between the LO3 and LB9 T5's besides the 1st gear ratio(2.95 vs 2.75)?
Larry.
Old Jan 24, 2004 | 06:21 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
5th gear was .63 (LO3) and .74 (LB9).
Old Jan 24, 2004 | 08:04 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Thanks. So strength wise the same then.
Larry.
Old Jan 24, 2004 | 08:16 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
If 89 or later, they should both be world class and the 2.95 is probably a little weaker b/c of the multiplying ratio. I'd consider them the same strength and there is definately a difference you can feel with those 2 ratios changed. I believe my LO3 with 3.73s cruises at a lower rpm than my GTA with 3.42s.
GTA @ 80 mph = 3000rpm
LO3 @ 80 mph ~2700-2800rpm
Old Jan 24, 2004 | 08:36 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
I kind of figured they'd be similar. When I go to the T5 it will be replacing a 2004R that has about the same 1st gear (2.74) as the TPI trans and about the same OD ratio (.67) as the TBI one. I can always change the OD gear. Should only be about 200 RPM difference though on the highway. The 2.75 low should be better with my 3.73 rear gears.
Thanks all.
Larry.
Old Jan 24, 2004 | 08:45 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Re: Difference between LO3 & LB9 T5's
Larry.
From every thing that I have read and seen, all v8 t5's were 2.95 1st gear, there was some misinformation printed that some had 2.75 first. The only difference is the 5th gear
RPO
m39 transmission .63 OD
MK6 transmission .73 OD
look here
Old Jan 24, 2004 | 09:17 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
My initial info came from thirdgenresource and showed that the WC TPI T5's from 89-92 were the 2.75 1st. I looked around some more and that's the only one that showed the 2.75. What the heck, eh? I was hoping for the 2.75 but if it doesn't exist then the 2.95 will have to do.
Thanks,
Larry.
Old Jan 25, 2004 | 10:51 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Thanks all.
Larry.
Hey Larry, hi from another Manual Monte guy. (we've talked before.)
Don't worry about trying to find the 2.75 first gear boxes. Most of the V8 T5s are 2.95 first / .62 fifth. The first gear WILL feel stronger than the first in the 200-4R. You'll like the 2.95 first gear with the 3.73s just fine.
Old Jan 25, 2004 | 10:55 AM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Thanks, I forgot about the swap you did.
Larry.
69GTOby
Apr 18, 2016 02:34 PM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
J.C. Denton
Sep 8, 2015 05:35 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
