Borg Warner Identification Help Please!
Old Jan 26, 2004 | 11:42 PM
350gts's Avatar
Car: 1970 HT GTS Holden Monaro
Engine: 350 chev
Transmission: not sure, purpose of joining ;)
hi
i have a 1970 HT Holden GTS Monaro with what i was told was an '84 camaro gearbox, a T5 Borg Warner. now that i've blown it up, i'm having trouble identifying it - i don't think it's a T5 at all, especially given the id numbers.
The box has these numbers:
13-38-065-901 Borg Warner Basic, 27 spline ..... on the tailhousing is 13-38-066-901.......
i've done millions of web searches incl archives on this site, but i can only get info on the T5 or muncie boxes.. haven't found anything with the numbers on my box.... can anyone help please?
thanks!
josh
Old Jan 27, 2004 | 09:59 AM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
josh,
You might try this site. At the bottom of the page is a # search. I didn't see anything with those #'s, all they show are ones that start with 1352. There is also a contact for these folks at the bottom too. If you go to the Home page there is a listing for a forum.
http://www.5speeds.com/t5/
Larry.
Old Jan 28, 2004 | 12:02 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
ok being that you said it says 13-38 I went to http://www.drivetrain.com/vartransp24.html
and this is what it says it is
BORG-WARNER T50 1976-79 Compact Cars (Monza, Skyhawk, ect) Inquire
Aluminum end-loaded case with the bearing retainer being cast as part of the main case. The bellhousing is not part of this transmission. It has a removeable tube that the throwout bearing rides on. The main bearing in this unit is comprised of caged needles in shell races. Loose needles and flat thrust bearings are used throughout the transmission. Casting number is 13-38 . Limited parts availability.
It is a old T50 Not A T5
6speedIROC
16
Mar 15, 2023 08:33 PM
PurelyPMD
May 5, 2016 04:57 PM
Vojtush31
Oct 11, 2015 01:07 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
scottmoyer
Sep 7, 2015 07:06 PM
