How in the hell do I remove the old unit in the differential?
Old Feb 1, 2004 | 05:11 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I got the axel tubes out of my rear end and can't figure out how to take the old unit out, I see bolts next to the splines but can't get them off because I can't lock the rear and my impact hammer can't get them off, how in the hell can I get that old unit off so i can put the new posi in? Thanks.
Old Feb 1, 2004 | 05:19 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Two bearing caps, two bolts each. The old diff should almost fall then.
Old Feb 1, 2004 | 05:20 PM
pasky's Avatar
Where they at bud? Trying to get this done before the super bowl. Only thing I have removed is the axel shafts and of course the differential cover.
Old Feb 1, 2004 | 05:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
right infront of your face. Once the cover is off there is two caps (cap)>{ gear }<(cap) they have two bolts a peice. Remove them and the ring gear/carrier will nearly drop out.
Old Feb 1, 2004 | 05:34 PM
Trying to find a pic, but to no avail...
They look like engine main bearing caps, and sit up-and-down at each end of the carrier. The bolts have like a 3/4" head on them.
Old Feb 1, 2004 | 05:40 PM
Here we go....
Attached Thumbnails How in the hell do I remove the old unit in the differential?-3426.jpg
Old Feb 1, 2004 | 05:43 PM
And if you're going to re-use the ring gear, those bolts are left-hand thread...clockwise to remove.
You do know how to set the backlash correctly when installing a new carrier, right?
Old Feb 1, 2004 | 05:45 PM
pasky's Avatar
I got those off bro, its just sitting in there gutless, I can't get it out, seems stuck. I don't have to remove anything else but the axel shafts right?
Old Feb 1, 2004 | 06:39 PM
pasky's Avatar
Heres what I got off, I can't figure out what is holding it in.
Attached Thumbnails How in the hell do I remove the old unit in the differential?-diff.jpg
Old Feb 1, 2004 | 07:43 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
somtimes a litte careful pring is in order!!! should come right out
Old Feb 1, 2004 | 07:59 PM
pasky's Avatar
Ummm, more specific please? I've tried smacking it with a hammer.
Old Feb 1, 2004 | 08:30 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Use a heal bar or a small crow bar. A little force and it pops out. Just make sure to note which shims were on which side and which way they were facing.
Edit: even a nice sized screw driver behind one of those ring gear bolts on the drivers side will pop it out easy.
Old Feb 1, 2004 | 08:33 PM
pasky's Avatar
Ok, i'll give that a shot tomorrow, i gave up today, are the shims for the carrier or the ones inside for the axel tubes?
Old Feb 2, 2004 | 12:24 AM
Here's where the shims are.
Old Feb 2, 2004 | 05:01 AM
ede's Avatar
ede
pry on it a little, nothing is holding it in. it should pretty much fall right out.
Old Feb 2, 2004 | 08:26 PM
Car: 1986 Iroc z28
did you get it out?
Old Feb 2, 2004 | 11:42 PM
pasky's Avatar
Been busy man, didn't get out of work ti'll 9:00pm, had to iron some clothes for tomorrow, I might go under there right now, just wanna do it when there is some light out incase a shim falls and I don't see where it came from =/.
Vintageracer
Jan 10, 2020 05:33 PM
EduardoRonaldo7
Sep 8, 2015 01:28 PM
Glowsock
Aug 26, 2015 12:28 AM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
