Wave plate in foward clutches?
Old Feb 12, 2004 | 11:58 AM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
Do all 700r4s have the wave plate in the foward clutches? I don't see one in mine just a regular flat style plate. I know it was rebuilt before maybe it was left out.
Old Feb 12, 2004 | 12:49 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Im pretty sure they all have the wave plate. How did the tranny shift?
Old Feb 12, 2004 | 07:07 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
It shifted firm but I had the covette servo and .500 boost valve installed. Other than that I never had a problem with it. I did notice that there is an extra steel that came in the new pack its a little thicker than the rest.
Old Feb 13, 2004 | 01:16 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
If i remember correctly, you have to have something machined then put the extra steel in, I seem to remember dana saying something about that once but can't remember exactly what.
Jason
Old Feb 14, 2004 | 06:36 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I don't think it would affect how it shifted, the forward clutch pack setup would affect how the car went into gear from park or neutral.
Old Feb 15, 2004 | 09:34 AM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I hope it will be ok then. I seemed fine before with thte same setup. But if its better to have the wave plate installed then I would rather do that.
Old Feb 15, 2004 | 11:53 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
the wave plate softens the engagement, leave it out if you like the way it feels now. I've seen some transmissions where you had to put your fingers in your ears when you went from park to drive.
Old Feb 15, 2004 | 05:11 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I'm more worried about durability. If it engages harder then couldn't it wear quicker?
Old Feb 15, 2004 | 07:44 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
the clutches usually wear longer with a harder apply. less time slipping into gear.
Old Feb 15, 2004 | 10:33 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I'm also running a 3200 stall converter so it should help some.
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
