need help! from guys w/ t-56 and SGI-5 BOX
Old Feb 15, 2004 | 08:03 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
how did you guys set yours up in your car i'm still not getting a reading from my speedo i'm using out#4 cant get it right!
Old Feb 15, 2004 | 09:36 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Why don't you buffer the T56 signal to a 4004 ppm signal and feed it to the DRAC box instead of feeding 2 outputs from the SGI box? That will feed your ECM, speedo and cruise with less work. I think.
Old Feb 15, 2004 | 11:23 PM
quickL98's Avatar
i dont understand? i have my pink wire from the harness for the vss going in to the "sig out " on SGI box, so instead i should have signal out wire just be from the cc buffer (yellow box attached to my ecm ) or is that what your callikng a drac?
please help
Old Feb 16, 2004 | 01:29 AM
jmd's Avatar
jmd
I might be missing something but is sounds like you're trying to do
T56 >-- to SGI --> out to ECM and out to speedo in two different formats.
I could be wrong because I don't own a Firebird
But the way I understood the MAF / electric speedo cars to work was
VSS at tranny >-- sends signal to DRAC module --> which feeds the 4004 ppm DC signal to the speedo cluster and the 2002 ppm AC signal to the ECM.
Why not set up your car like this:
VSS at T56 >-- into SGI box to change signal down to about 4004 ppm --> to DRAC module which will feed everything like stock.
Old Feb 16, 2004 | 10:00 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I set mine up like this (IF I'm remebering things right):
VSS - wire A to "sig. in" on SGI
VSS - wire B to chassis ground
12 acc power to power on SGI
Chassis ground to ground on SGI
"out 3" on SGI to ECM
I could be wrong, but thats what I remember. The six speed has been in the car for a couple of years now.
Old Feb 16, 2004 | 11:39 AM
quickL98's Avatar
thats how mine is set-up however i do not the cruise in the car any more (dont ask ) so i wonder if thats why my speedo is not working but the car is able to idle now .
i'll try it both was and double check my szhit
Old Feb 16, 2004 | 11:42 AM
quickL98's Avatar
i'm using out 3
vss signal wire is in the sig in slot
vss sig out wire is in out 3
power is in power and grounds are appropriately mounted
i'm thinking that the cruise being removed is why my sppeedo is not getting a sig.
what do you guys think?
Old Feb 16, 2004 | 12:29 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Nope. I think you are not getting a signal because you are using VSS wire B for signal in when you should be using wire A.
Try using the OTHER VSS wire for signal in.
Old Feb 16, 2004 | 05:47 PM
quickL98's Avatar
the drac is the yellow box mounted to the ecm correct
Old Feb 16, 2004 | 06:38 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Originally posted by quickL98
i'm using out 3
Two wires come off the VSS. One goes into the SIG (signal wire coming from vss). The other goes with the ground. It should not matter which VSS wire you use for the SIG or ground.
Old Feb 16, 2004 | 07:02 PM
quickL98's Avatar
if the SGI box is recalibrating the signal from the LT-1/T56 vss to tpi vss connector doesnt that end up at the drac and ecm
whats the flow of informantion?
vss output signal > ecm> drac> speedo in dash
the VSS also aids the IAC , i would think the sig would go to the ecm first right?
Old Feb 16, 2004 | 09:18 PM
quickL98's Avatar
i think i've got bigger problems any how. i think my ecm is going out , i keep getting strange codes and weird things are happening while watching the scanner so as of right now my vss is like #next to last
InfernalVortex
Apr 20, 2021 11:31 AM
86CamaroDan
Sep 29, 2015 10:08 PM
BLK87Z
Sep 18, 2015 11:29 PM
TrevinE
Sep 14, 2015 03:20 PM
mx127
Aug 10, 2015 08:13 AM
