What would cause a flywheel to grind after replacing a clutch?
Old Feb 28, 2004 | 02:49 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I think my brother in law goofed up when he reinstalled his clutch on his t-5 and when he starts it, it grinds nasty. It isn't the starter we checked that, sparks are flying out from the bottom of the bellhousing....any ideas?
Old Feb 28, 2004 | 04:59 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Clutch disc is in backwards, or the throwout bearing was put on the fork backwards.
At any rate, it's gotta come back apart to find/fix whatever the problem is. It should be pretty apparent what the problem is when it gets dis-assembled.
pasky's Avatar
Yea, found out the throw out bearing is loose. Thanks for the help.
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
hokis
Aug 9, 2015 03:57 PM
rsrmoore
Aug 7, 2015 08:44 PM
