Axle
Old Mar 4, 2004 | 01:52 PM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
Axle
I just found out that my right axle is slightly bent, where can I buy a new one? A junk yard? I don't have the slightest clue as to where to buy a stock replacement axle.
Old Mar 4, 2004 | 01:54 PM
ede's Avatar
ede
gm parts, used from a junk yard, and there are several aftermarket sources
Old Mar 4, 2004 | 03:48 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
You should have 26-spline shafts, unless someone swapped the rear in the car. The spline count is important, as is the rear brake type (drum or disc). You will need this info when getting a replacement.
Old Mar 4, 2004 | 04:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You'll also need to know whether it's a 9-bolt or a 10-bolt. It's probably a 9, which won't make it any easier to find one. But at least you won't have to worry about the spline count because those ar eall the same.
Old Mar 4, 2004 | 04:13 PM
Car: 1988 GTA
Engine: 355
thanks ppl
Old Mar 6, 2004 | 01:29 PM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
26 SPLINE AXLES AVAILABLE
I HAVE 2 26 SPLINE AXLES RIGHT OUT OF MY IROC IF YOU ARE INTERESTED.
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
