Transmission mounts?
Old Mar 13, 2004 | 04:15 AM
shapeshifter's Avatar
Car: 1984 camaro
Engine: 60*V6
Transmission: 5spd
Hi everyone...
I have a few questions. after driving a little hard on my car, i noticed that in first and second gear mainly my shifter goes up and down... did i bust some transmission mounts or something? how would i go about fixing it? and lastly... will it do any damage driving like this? Thanks a ton
Old Mar 13, 2004 | 05:10 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The transmission mount is very easy to replace. Just jack the transmission up enough to support it while you remove the support brace. Replace the mount and put the brace back on.
Old Mar 13, 2004 | 12:38 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I put a jack under the torque arm, not sure if thats a bad idea, but it worked. This is how I did it.
Take off the bolt on the mount
Jacked the tranny up
Removed the crossmember so I could get in there easially (not necessary)
Took off the 2 bolts for the mount
Put the new mount on
Reattach crossmember
Lower transmission
Put mount bolt back on
Oh, and it didn't line up when I did it, someone had to pull the transmission over so the bold on the mount would to through the hole on the crossmember.
It costs $12 and takes a few minutes to change, it isn't worth risking damage for that.
Old Mar 13, 2004 | 05:51 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
yes it will do damage, just drive her nice untill u fix it, do u her any thumps??
Old Mar 13, 2004 | 09:59 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Maybe im just lucky but my trans mount has been broke for like 3 or 4 years now without any problems.
Old Mar 13, 2004 | 10:14 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Its 10 bucks, go fix it.
Old Mar 14, 2004 | 12:56 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Exactly why would you drive it around for 3 or 4 years when you knew what the problem was?
Old Mar 14, 2004 | 05:23 AM
Car: 1984 camaro
Engine: 60*V6
Transmission: 5spd
hahahaah. i felt guilty all day driving it, because there was no way i could fix it today, but i had to go do some stuff. babyed the crap out of it though. I only have one jack... will i be able to pull it off?
Old Mar 14, 2004 | 09:47 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
sure, jack up the car and put jackstands under it, remove the jack and then jack the trans up just to support it, dont actually lift it much at all.
Old Mar 14, 2004 | 10:26 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
You shouldn't be under the car at all when its supported only by a jack. Go get yourself a set of jackstands, or even ramps will do.
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
