massive wheel hop. whats broke?
Old Mar 18, 2004 | 11:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok at the track last night, after shortly installing my energy suspension tranny mount, on my first run, i got massive horrible wheel hop off the line, nothing like this ever happened before, so i ran a second time and same thing happened. i beleive something is broke. what could it be? a torque arm?
Old Mar 19, 2004 | 12:35 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
dunno if my post made sense, but what i am thinking now is.. since i never got hweelhop before, and now i replaced my tranny mount with a high performance energy suspension mount, and then after that install ig et wheel hop. the tranny mount had something to do with it?
Old Mar 19, 2004 | 01:03 PM
MdFormula350's Avatar
did u use the metal plate that comes with it? if so take it out, casues vibrations and possibly other things.
wheel hop at the track happens when u get good traction and either the shocks or the lower control arms cant handle it.
i would say take a look at ur lower control arms, mine were bent alittle/ you cou tell they were flexing alot.
i would invest in some lower control arms wiht polybushings and see what happens.
also make sure you have the proper tire pressure and that its equal on both sides.
most liekly something isnt broke, jsut bent or wore out in the back.
Old Mar 19, 2004 | 07:39 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
I know this is a little off topic, but i took my car to have the front end aligned and they said that the rearend was not in straight. Could the LCA's have anything to do with this, if they were to be bent? Also, what else could possibly cause this if bent LCA's is not the problem? Thanks for the help
Old Mar 20, 2004 | 12:45 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
the instructions strongly urge leaving the plate on, even though i do think i tmakes the tranny sit higher up, cuz the driveshaft seems to not fit in as far as it did before (can see the oil line where it used to line up)
im not sure what the control arms are? where are they located in the rear? and which way do they go?
also if i launch on the street, it seems to be fine, its just at the track, its HORRIBLE.
Old Mar 21, 2004 | 12:59 PM
yeah control arms go from the body to the rear end, one on each side.
White91GTA the panhard bar could be bent some and cause the side to side straightness to be off.
Old Mar 21, 2004 | 01:43 PM
White91GTA's Avatar
Engine: 5.7L TPI
thanks for that...i have heard that from a couple of other people, so i will have to look into a new one and hope that fixes it.
Old Mar 21, 2004 | 01:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Here is a pic of my bent pan hard bar before I welded the pipe inside of it.. next pic will be my wide LCA.
Someone must have used the LCA to jack up the car, the LCA widened out and bent the pan hard bar.
Somehow everything drive and handles fine.
Even better after I boxed everything off.
Old Mar 21, 2004 | 01:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
.... Its not as wide as it looks but close.
Old Mar 21, 2004 | 02:53 PM
White91GTA's Avatar
Engine: 5.7L TPI
i will have to look at mine then...i can't remember ever jacking on the lca, but it is possible
Old Mar 21, 2004 | 05:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
stop hijacking my thread!
Old Mar 22, 2004 | 01:46 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
No I have commandeered your thread.
Chiknhawk
Wheels and Tires
Jan 29, 2017 10:19 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
