slight T56 issue
Old Mar 26, 2004 | 11:55 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
slight T56 issue
when my trans is cold, like on a cold day outside, its hard to get into gear... i mean, i have to match revs for it to go in..
now i normally do that anyway, but even if i dont, and its just somewhat close, it should go in.... it IS a production car trans.. GM doesnt expect everyone to match revs to shift...
but..... when my car is warm, it behaves perfectly normal... goes easily thru every gear, and is pure joy to drive..
so what makes it hard to get into gear when cold?
one more side question... my clutch lets out at the very top of its stroke.. i mean, the pedal is almost all the way up before it fully engages... is there a simple way to adjust it down so it engages fully at 3/4 of the way up?(and still fully disengages before the pedal goes to the floor) its kind of a comfort thing for me, athough every T56 ive ever driven is like this....
Old Mar 26, 2004 | 12:11 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Dont think its possible. Another reason I like the mechanical linkage . As far as the cold gearing, what type of fluid did you put in?
Old Mar 26, 2004 | 12:17 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ATF... dextronIII
id change it if i could find some mobile 1 ATF... but noone carries it around here
Old Mar 26, 2004 | 01:17 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Thats exactly what i used to think...
Just wait untill it starts breaking on you. you'll begin to hate it more than you'll ever know.
after your pedal arm has broke, the z-bar has busted, you can't find new parts, have to have the old parts welded, and your clutch won't ever release at the exact same point, hydraulic linkage is the only way to fly.
Old Mar 26, 2004 | 02:24 PM
Fbody fan 35yrs's Avatar
Car: 91 Z/28
Engine: 5.0
Transmission: T-56 6 speed
I bought a new slave cylinder at Oreilly's, for around 37 bucks, pumped out the bubbles, and put it all back together. All shifting has been perfect since. Hot or cold.
Old Mar 26, 2004 | 03:38 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
i have that same problem but only with 5 gear. it wont stay in unless i match the rpms. its annoying
Old Mar 26, 2004 | 04:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
oh, my gears stay in when i get them in gear..
i can just feel what "FEELS" like teeth bumping instead of meshing when i try to put it in gear...
if i blip the throttle i'll go smoothly. its just annoying.
ive never had it come out of gear though
my master and slave cyl are BRAND NEW straight from GM... preblead too..
Old Mar 26, 2004 | 05:16 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
It sounds as if the clutch isn`t completely releasing and the trans is still slowly spinning making it hard to go in gear. Try this next time put it in reverse, then try to put it in first gear and see if it goes in easier then
Old Mar 27, 2004 | 08:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
heh.
i have to put it in first before i can shift to reverse
Old Mar 27, 2004 | 08:37 PM
kevinc's Avatar
Car: 1982 Z28
I'd pull the slave cyl and check to be sure the fork is seated on it's pivot correctly. If it popped out during installation, it won't pull the pressure plate correctly causing the clutch not to disengage fully...and make shifting clunky.
Old Mar 27, 2004 | 10:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd suspect the pilot bearing / bushing.
I would not in any case suspect anything to do with the hydraulics.
Old Mar 28, 2004 | 06:58 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I agree with RB, sounds like a pilot bushing/bearing problem. If it was one or two gears you might suspect a synchro, but if it's every gear then it's something on the input side of the trans.
There is no easy way to alter your engagement point for the clutch. McLeod makes an adjustable slave that would do the trick though.
19irocz85
Aug 31, 2015 10:31 PM
19irocz85
Aug 26, 2015 07:54 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
