Anyone tried the Cobra IRS in an F-body?
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
The Ford 9" rear end fits... how about the IRS from the Cobra?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Anyone tried the Cobra IRS in an F-body?
Re: Re: Anyone tried the Cobra IRS in an F-body?
Originally posted by ShiftyCapone
One is a solid axle and the other is not. Two completely different animals. A ford 9" is not a direct bolt on either by any means.
I take it the Ford 9" kits require a little bit of leg work too... they just have all the parts necessary to make it work?
Car: '90 RS
Engine: 377 LSX
Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
So you're sayin' it wouldn't work? Or at least not without major modifications.
Re: Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
With enough money anything will work. A ford 9" takes serious work because it is nothing like our rear. The guys who run them have aftermarket ones that allow us to use our torque amrs and everything else. The ford IRS would be pointless. The only IRS I would even think about converting to would be from a C4. The Ford IRS is nothing special.
What are the main differences between running an IRS or a live axle? I started thinking about this earlier after I saw pictures of a Miata with a 2003 T-bird rear end. Said car is waiting on a supercharged LS1 to be installed in it
Car: '90 RS
Engine: 377 LSX
Re: Re: Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
Yeah... I was thinking any IRS period would be pretty cool. I thought the Cobra IRS would be easy because the Ford 9" was doable.
Re: Re: Re: Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
An IRS rides better and handles better theoretically. When one side of a solid axle is loaded the other side will react as well. This can compromise traction for the wheel that is not going over a bump. Also an IRS is mostly attached to the body and has a very small amount of unsprung weight. IRS systems are the way to go but a solid axle can perform with the best of them when set up properly.
Car: '90 RS
Engine: 377 LSX
Re: Re: Re: Re: Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
How hard do you think it would be to install the C4 IRS into a 3rd gen?
Re: Re: Re: Re: Re: Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
It would be very time consuming and expensive. You would have to hack the rear up pretty good in our cars. You would also have exhaust routing problems and a whole bunch of other stuff. I am sure it can be done but I am happy with my solid axle for now.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Re: Re: Re: Re: Re: Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
Cool, thanks. Just another pipe dream I suppose. One of these days when I get filthy rich, my mechanic and I will look into it further
funny think you mention the cobra IRS... because cobra guys ditch them and swap in the solid axle.
the only thing a IRS is good for on the dragstrip is snapping halfshafts.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
Originally posted by MrDude_1
he cant do it.. you need a fabricator.. not a mechanic.
I'm interested in more of an all around experience with my car, more than just the strip since I hardly drag and I have yet to go. Though the posi in my stock axle is dead so I am looking for something. Ford 9" with discs seems to be a safe way to go... it's strong as hell, does it have any attributes that make it hold the road better handling wise?
Car: 91 Camaro Vert
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Anyone tried the Cobra IRS in an F-body?
He's good friends with someone who builds tools and parts for him we he needs them
not really. the 9" is stronger, and thats about it. when modded for 3rdgen use, its basicly identical to the stock one, only stronger, a lil heavier, and someone always brings up the greater power loss thru it...
i just love it for the piece of mind you get by knowing your rear wont blow out when you dump the clutch.
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
I can tell you the C4 is the way to go. Get yourself a Dana 44 when you do it though, otherwise you'll be replacing the diff pretty soon if you have any power. It is expensive, but it's getting cheaper every year. The rear suspensions used to go for right at $1500-$2000 and now they can be had for under $1000. Make sure you get everything out of the donor C4. The other great thing abut the C4 IRS, is it requires no modification to go in. By that I mean that the suspension itself can be installed in absolutely stock configuration. There is substantial cutting and welding to the car required to install it, but you don't even need to modify the fuel tank. Exhaust routing is a piece of cake, you just run the pipe directly under the driveshaft (just like the C4) and use small round mufflers, like I said, cake. Here is some pics.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i was looking for those pics....if you look in the top pic at the exhaust before it bends to the drivers side you can see a vertical weld....Think of a reverse y-pipe
C4's can launch VERY hard...there are a few guys on here who cut really good 60 footers...its that mustang IRS that doesnt launch aswell
Car: 94 Corvette
Engine: LT-1
I have a few other pics of the rear install as well, but I didn't want to post them all. f-crazy, you are exactly right, that is like a backwards y-pipe there. Basically the pipes come down off the headers, thru seperate cats (it go a 425rwhp LS1 too) into one 3 or 3.5 inch pipe (can't remember) into a round Dynomax muffler (it's not installed in the pic) then it splits into two 3 inch pipes for the exit at the rear bumper. It is super fast, handles so nice and runs in the low 13's to high 12's at 5280 feet. Two seperate Vipers have fallen prey to it, and more Cobras than one would care to count. Nobody takes it serious, I mean c'mon it's an 87 IROC, how fast can it be?!?
Car: 91 Camaro Vert
heh, btw i said somthing wrong above...
i said somthing along the lines of " A IRS is only good for snapping halfshafts"
i ment to say " the cobra IRS is only good for snapping halfshafts"
anyhoo... post up thoes pics!
88SS6SPEED
Nov 11, 2015 07:05 AM
