Not a car guy, needs your help
Old Apr 19, 2004 | 07:09 PM
schragnasher's Avatar
Im the farthest away from a car person as it gets but ill try to explain this as best i can.
Ok so i got this old '86 Camaro. I was recently driving it along and stopped at a light. Light turns green i hit the gas and i don't think it liked it. Cars dies in the middle of the road. Oil is present and gas. Car doesnt start.
Get it to a shop and the say its the carborator, "i think", said its not getting a spark. They replace carborator, car starts.
Although cars starts it sucks. The repair guy says there is still transmission problems. It will not get up to speed nearly as fast as it used to, takes a couple minutes to reach even a somewhat desireable speed. Stops just fine.
What could this be? Transmission fluid? PLease give me a clue so if i do take it somewhere i don't get totally ripped off.
Old Apr 19, 2004 | 07:15 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
What exactly do you mean by it takes a few minutes to get to a desireable speed?
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
need more info
is it a v6, v8? was it always a carb or did someone retro it? did you do a tune up (or have one done) when you bought it? where was the oil and gas coming from, has it happend before?
personally I've found the best way to not get ripped off is to do the work myself (granted I'm still learning but gotta start somewhere). barring that get refrences from people you know or from the better business bearu. well that should help people get you started.
Old Apr 19, 2004 | 07:18 PM
It is sluggish, ill hold the gas down but it does seems to get really low RPM's. It seems to get better if i pump the accelerator.
Old Apr 19, 2004 | 07:20 PM
Its a V6, im not sure of much of its history. What do you mean by where was the gas and oil coming from? This has not happened in the 3 years iv had the car.
Old Apr 19, 2004 | 07:21 PM
Oh i dont mean there was oil and gas around the car i mean thre was oil and gas in the car.
Old Apr 19, 2004 | 07:22 PM
dankhound's Avatar
Car: 91 RS
Check and see that the throttle blades in the carb actually open when the pedal is pressed.
Old Apr 19, 2004 | 07:26 PM
LOL is that something i can easily check? Like i said man, ima computer nerd i only change oil and tires. I got no problem giving it a shot though ill take a look in my manual see if i can figure it out.
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
you should have a tune up done, its amazing what changing a few parts can do. I'm also wondering if the carb is adj right, maybe running rich. just my opinion
Old Apr 19, 2004 | 07:32 PM
dankhound's Avatar
Car: 91 RS
Hehe ok. Theres a wing nut ontop of teh aircleaner lid(big round thing ontop of engine). Take that off and remove the lid. Look down inside and youll see two or four round holes with a plate at the bottom. When you press on the gas the plates should rotate out of the way so air can get in.
Old Apr 19, 2004 | 07:34 PM
Thanks ill give it a look once i get this thing home, hopefully noone will kill me for moving so slow.
Old Apr 19, 2004 | 07:44 PM
dankhound's Avatar
Car: 91 RS
One other quick thing i thought you could check is for a plugged exhaust. Theres two methods. You can plug up the exhaust pipe and see if the engine revs any differently. You could also use your hand to feel for more exhaust when the engine is reved but it takes time to get the feel of it so id suggest using the first. You dont have to drive the car around to do it. You can do it in park.
Old Apr 19, 2004 | 10:19 PM
ok its too dark to check the vents. But when i got home i noticed something. When i got out i smelled a burning smell. This may be 100 things i dunno but might help diagnose.
Old Apr 21, 2004 | 07:19 PM
dankhound's Avatar
Car: 91 RS
Check the trans fluid and let us know the color ad smell of it? If it smells burned it at least needs to be replaced. Might even be time for a trans rebuild.
MustangBeater20
Oct 29, 2022 09:20 PM
RazorN8
Jan 7, 2022 11:44 AM
86IROC112
Aug 17, 2015 02:00 PM
bryan623
Aug 10, 2015 11:33 AM
