tranny wont engage
Car: 88 GTA
Engine: 355
tranny wont engage
Ok I posted about this in the tranny forum too but didnt get much of a response. Well after 10 months of building up my GTA from stock to 355, the tranny wont engage. I finally got it running and it sounds like a beast! But now it sucks cuz I cant drive it anywhere. Im wondering what wouldnt make the tranny engage at all. All wires and the tv cable are hooked up. I got a used TC from someone on here and the tranny itself came from my camaro that was wrecked before.
There is a whine that comes from the engine whenever I rev it. I dont know whether it is something from the tranny or the double chain timing gear I put on. It is pretty loud and sounds like a supercharger. If anyone else needs any more info to help me out, I'd happily provide it.
Also how could I check if it is actually the tranny or the TC giving me the problem?
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
First I would make sure there is oil on the trans stick while the engine is idling in park.
There is a good chance that if there is no oil on the stick the fluid level is too low for the pump to send the fluid through the trans.
Car: 88 GTA
Engine: 355
ok i will double check that tomorrow. We put 5 full quarts of oil in it so I think that is how much it holds. Before we ran the engine after the breakin with the new oil, we checked and it was fine.
Does anyone have experience with those double chain timing belts? Do they really sound that loud?
Car: 88 GTA
Engine: 355
hey thanks alot mods for moving this topic. The TECH/general engine forum is fine for this thread. I guess it doesnt matter now though since Im not getting much of an answer from anyone anyway no matter where it is.
If the trans fluid is at the correct level and it still wont go into gear, then I would have to say there is a mechanica failure in the valve body of the trans or a burn't clutch pack. No I don't have any experience on the double roller chains. They shouldn't be loud though.
Car: 88 GTA
Engine: 355
well i might have found out the problem via pro built automatics. He is very knowledgable it sounds. I think it might be because I put a 30 spline TC on an 83 tranny which uses 27 spline TC's. I hope that is the reason so I really dont have to buy much. Thanks for trying to help.
That would make sence and make alot of noise since the splines weren't lining up. I hope nothing was damaged in the process.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
