rearend
Car: 82 z-28
Engine: L69
Transmission: muncie T-10
rearend
okay, i need to know how many splines are on my rearend setup. I know its either 26 or 28. Its a 7.5" gm 10 bolt. Stock rear on an 1982 z28. any help would be appreciated
Car: 82 z28
Engine: 400ci 450hp
What's the difference on when the 9 bolt and 10 bolt were used. I also have a 82 z28 and my car is at my shop trying to pick up some parts to convert the brakes. Would mine be a 10 bolt same the 82 z28 above
![huh](https://www.thirdgen.org/forums/images/smilies/huh.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Firebird
Engine: 2.8 V6
I believe so... the '82 Z28's with the L69 and manual trans got the same axle as the '84 T/A's w/L69 and manual trans, right? The 3.73/posi/disc rear? That one was a 10-bolt.
Not sure where the 9-bolt came in, but I think you guys should have the same rear axle. And if you've got rear disks, keep in mind the recall and recall kit: https://www.thirdgen.org/techbb2/sho...threadid=78725
Only difference between 82-83 rear axles and 84-92 rear axles is that the 82-83 brake lines have standard/SAE double-flares. 84-92 brakes use metric/ISO bubble-flare lines. That goes for 9-bolt axles, too.
Car: 82 z-28
Engine: L69
i hate to tell u thing, but the 82 camaros didn't have an l69 option. I swapped that into my car, the l69 wasn't an option in the camaro until 83.
Just to clear up any confusion
Car: 4
Engine: 6
Transmission: 5
Yup, no 82 L69.... it became available late in the 83 model year (like around March or so). But like the man said, with a swap, about anything is possible.
Yes the T/A and Z28 L69 drive trains for a given year were the same; however the 83 got a mechanical clutch linkage, but the 84 got hydraulics. Not all were posi or disc brake. Mine was non-posi and had aluminum drums.
Car: 82 z28
Engine: 400ci 450hp
Mine is an 82 z28 with an automatic and I have drum brakes. Trying to get the right pieces to change over to rear disk. I have all the stuff located for about $200 to change over to the Ls1's. My understanding is the Ls1 change is possible withe the 10bolt
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
UltRoadWarrior9
04-28-2020 10:39 PM
