t56 problems
Old May 29, 2004 | 04:49 PM
white88formula's Avatar
Car: 2000 Chevy Tahoe
Engine: 5.3 v-8
t56 problems
OK, everyhting went in GREAT except 1 thing, the damn mastercylinder, i figured out how to bolt it to the firewall, teh prob im haveing is attachin the mastercylinder to the pedal...how did everyone else do it??? please help my car is stuck at the shop :-(
drew
Old May 29, 2004 | 04:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take the gray bushing out of the MC rod and use the T-5 plastic clip; or drill it out and use the T-56 metal clip.
Old May 29, 2004 | 05:02 PM
Engine: 5.3 v-8
there wasn't any bushing on the m/c rod, just a hole but there was some sleeve on teh pedal?? at least it looks like it,
Old May 29, 2004 | 09:05 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Its a grayish black bushing on the master cylinder, I took a dremel and took it off and then just used a brake pedal clip to hold it on the pedal. Can get the brake pedal clip for like 2 bucks at the dealer.
Old May 30, 2004 | 03:09 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Or loot it from the junkyard for free!
Seriously, I used another brake clip too. Works like a charm.
Old May 30, 2004 | 03:34 PM
Engine: 5.3 v-8
alright im gonan try the break clip thing i just have to take it all back out again, ohwell, but anymore ideas would be appreciated
drew
Old May 30, 2004 | 04:29 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
the master should slip onto the clutch pedal with the pedals installed. If you loosen the 4 nuts and angle the pedals slightly, does that let you slip it onto the pedal?
Old May 30, 2004 | 06:02 PM
Engine: 5.3 v-8
ill try that also it was realy tight trin to slide it on, the thing that really sucks is you have absoultly NO room under those dashes, but ill try both ways
drew
Old May 31, 2004 | 08:50 AM
Recline the seat all the way and lay on it with your feet towards the headrest. Put the wheel all the way up, or remove it. That's the best way to get under the dash.
Old May 31, 2004 | 08:55 AM
jmd's Avatar
jmd
:werd: It sucks when you're tall but works the best.
Old Jun 2, 2004 | 08:51 PM
Engine: 5.3 v-8
thanks alot guys, i took a flat head screw driver to the m/c and popped the plastic bushing off the rod, slid right on then i had teh clip from the dealer and it all popped right on, man its alot cooler witha 6 spd, now just have to replace the oil pan seal. haha, when i was replacin the rear main i saw it was in really bad shape and now it leaks like a mother f@*$^!, but hey i got a 6spd.
drew
19irocz85
Aug 26, 2015 07:54 PM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
