Need Help, Need T-5 Pics
Old May 31, 2004 | 12:31 PM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
i just picked up a used T-5 from a boneyard. i dont know much about em, ive always had automatic f-bodies. i was wondering if anybody out there had any pics of their tranny freshly pulled including bellhousing etc... im curious to see how the clutch fork, linkage and such are supposed to look. and also it looks like theres some sort of line cut on the tranny. but like i said i have no experience with these trannies...
thanks again guys
Old May 31, 2004 | 01:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the "line" comes from the top of the trans about where the case and the extension housing bolt together, it's the vent, and it goes nowhere. There's supposed to be a little white cap in the end of it.
If it comes from the slave cylinder mounted on the bell housing, it's the hydraulic clutch line from the clutch master cyl; the JY just boned you; because you can't buy that line. You'll need to go to the dealer and buy the pre-filled pre-bled assembly of the 2 cyls, the resrvoir, and the lines between them.
Do you know what kind of car all this came out of.... what year and engine? What are you trying to put it into?
Old May 31, 2004 | 01:13 PM
The transmission came out of a 84 t/a and its going into my 84 z28 both L69s The line that is cut looks like its a feed from the slave? to the master... a half inch thick black line... pretty sure its the slave.
Old May 31, 2004 | 01:15 PM
man, i just re-read what you said at the end of your post
damn... so theres no way to get around that huh... stupid junkyard... well i guess its my fault for not knowing.. how much would somethin like that go for
Old May 31, 2004 | 01:59 PM
60504's Avatar
Car: 92 Camaro
Engine: ZZ4 350 HSR
Transmission: G-Force T5
Roughly $100 - try www.gmpartsdirect.com for the best price.
It is not hard to change - just make sure to get a NEW slave unit so it is ready to go without any bleeding...a used one may just cause trouble after it is installed.
Old May 31, 2004 | 02:02 PM
well that sucks
anyway... i also wanted to see some pics so i can see how the shift fork is hooked on from the slave
Old May 31, 2004 | 03:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not much to show in a pic....
The fork just clips onto the ball stud in the standard way, and the end of the slave cyl rod just fits into the cup on the end of the fork... the slave cyl bolts to the rear face of the mounting flange; the bolts go through from the front and thread into captive nuts in the shield bracket; the line goes into the slave from above. Pretty much a no-brainer. I think it's the only way the parts have any possibility of going together.
Old May 31, 2004 | 05:36 PM
ok cool
thanks
now, is the slave any different for other years such as the WC or are they all the same slave?
Old May 31, 2004 | 06:37 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Originally posted by EatFordShtDodge
ok cool
thanks
NWC & WC used the same bearing retainer, throwout bearing, clutch assy., bellhousing, ballstud, fork, and pedals, and hydraulics 84-92. They updated the PN's over the years but it's all interchangable stuff.
Old Jun 2, 2004 | 03:56 PM
Old Jun 2, 2004 | 04:01 PM
Old Jun 2, 2004 | 04:04 PM
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
