If you take the ecm out....
Old Jun 17, 2004 | 06:47 PM
treeohfive's Avatar
so this topic touches on a few general area's so ill stick it here in the line of traffic.
92 rs...
wondering What sensor(s) tell the ecm to lock up the TC.
Will the TC lock-up take place on this car even though its carbed?
i still have the ecm, was just wondering if i could run it, or if i had to buy the TCI setup.
Old Jun 17, 2004 | 06:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
VSS, TPS, MAP, 4th gear switch (although that can vary from PROM to PROM).
Old Jun 17, 2004 | 06:53 PM
treeohfive's Avatar
ty, that answers my question entirely. if the FI is removed, nothing will make the TC lock up other than the ALDL switch and the TCI type switch.
correct?
Old Jun 17, 2004 | 07:00 PM
five7kid's Avatar
The power will still be going to the tranny. All the ECM does is ground the return wire to lock up the TC.
So, you can use a "normally-open" 4th gear switch that grounds when pressurized, hook that up to the return wire of the solenoid, and the TC will lock as soon as the tranny shifts to 4th (OD). It will still unlock when you hit the brakes, because that cuts the power to the tranny.
Old Jun 17, 2004 | 07:16 PM
treeohfive's Avatar
A manual flip switch? What solenoid? sorry...not much of a tranny man.
Old Jun 17, 2004 | 07:34 PM
treeohfive's Avatar
so what all will it hurt if i say to hell with the TC lock-up?
And isnt the TC supposed to disengage at WOT as well? how would that be solved?
Old Jun 17, 2004 | 09:01 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Pressurized switch. It does the switching for you when the tranny shifts into 4th.
The tranny shifts out of fourth in WOT (actually well before), thus no probs there either. You can add B&M's downshift kit to keep the tranny from downshifting at part throttle, but I've never really had the need for one myself.
Old Jun 17, 2004 | 09:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could also use a vacuum switch.
Old Jun 17, 2004 | 09:27 PM
treeohfive's Avatar
lol i need in depth explainations honestly.... *a vaccum switch* helps none at all....cause i dunno what it is, how it works, where i hook it to, where to find one.
Question.....how did Older cars with no ECM run without the TC lock uwhat about when it downshifts into third and its at WOT? the tc will still be locked up.
i think id sooner rig the TPS up to the carb and just plug the ECM back in.....
would one of you be so kind as to IM me on AIM so we dont have to clutter up the board. AspiredTwo
Old Jun 17, 2004 | 11:26 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
A good tranny shop can set it up so it locks the TCC by itself w/o the ECM.
I discussed this with a guy when I was considering a built 700r4.
Old Jun 18, 2004 | 12:05 AM
treeohfive's Avatar
yes, BUT can they do it cheaper than 70 bucks
also..i can manually lock the TC...i want it to be a hands free operation though...i dont want to have to flip a switch every time i hit 4th gear.....
Old Jun 18, 2004 | 12:09 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They used a 4th gear pressure switch, a vacuum switch and a brake switch.
Old Jun 18, 2004 | 12:11 AM
treeohfive's Avatar
then thats what i need
anyone know whatll work? specific parts or part numbers?
Old Jun 18, 2004 | 12:19 AM
five7kid's Avatar
This has been discussed often on the tranny forum. Diagrams and everything. I suggest you search over there.
Old Jun 18, 2004 | 12:42 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
run a wire from you a and f terminals on your aldl connector connected by a switch and you can manually activate lockup
Old Jun 18, 2004 | 01:13 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Drop the pan, remove the existing 4th gear clutch switch from the valve body, it's the one with only one terminal. Replace it with a GM P/N 8642473 switch. Wire a 14014519 vacuum switch between the wires to pins B and C of the factory TCC connector, and give the switch a source of ported vacuum.
Old Jun 18, 2004 | 01:14 AM
treeohfive's Avatar
yes this is how its done now.
i wasnt aware of the fact that the ECM controlled the lock up....so for a year now ive been running the car with no ecm and had no clue the ecm locked it up....thought the torque converter relyed soley on the rotating mass.....
wonder how much damage i did to the tranny (1 year old)
Anyways...i found a vaccum activated switch....specs are
"This is a normally open switch. It takes 7 pounds or more of vacuum to lock the converter and 3 pounds or less of vacuum to unlock the converter.)"
38 bucks.
now im wondering at what rpm range the TC will lock up using this.
Old Jun 18, 2004 | 01:22 AM
treeohfive's Avatar
apeiron, are both those gm part numbers?
is this a gm only part or can i get it at the local autozone?
Is this anything major i have to do with the valve body or is this real simple. im real shady of messing with the tranny (yet completly willing to rebuild a rear end or engine....and port and polish heads) ALL with no prior experiance and no physical help. all done by reading how-to's lol
Old Jun 18, 2004 | 10:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
GM part numbers, you'll have to go to a dealer. Changing the switch is easy, you unscrew the old one and screw the new one back in.
<img src="http://www3.telus.net/~crussel/tcc_wiring.gif" width=100%>
Old Jun 18, 2004 | 10:19 AM
treeohfive's Avatar
thank you VERY very very much, you have been very informative and helpful. i hate when people go *ah i give up on you!* were all here to help and learn ...we need more people like ya around...once again i greatly appreciate it man.
Old Jul 16, 2004 | 04:48 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i'm not 100% if this was stated in here, but how do you setup to lock in 4th gear only? I'm not to worried aobut the around town driving, but 4th would be great, 40+ mph roughly, and could help keep that tranny cool. I'm in the middle of a 4th gen dash swap, have most things working, (unfortunately i think i toasted my computer) and since i have an 85, it's a cable speedo, so i need to add a later model VSS w/ buffer box for speedo to work, and probably for the Computer to see how fast the cars running. HOwever, i'm a tad curious about finding out if i can make my car's TCC lock in case everything doesn't work out...(need to tkae this car to school .... 200 miles away. still got a month to finish up.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
