Tailshaft housing bolts
Old Jun 22, 2004 | 06:41 PM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
I had to change the speedo gear. Im not sure what to torque the 4 tailhousing to unibell bolts to on my 700r4. Cant be too much because of it all being aluminum. A specific torque would be greatly appreciated. (Haynes manual doesnt have the spces in it)
Old Jun 22, 2004 | 06:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Torque goes with hardware size, not casting material.
Should be around 30-35 ft-lbs.
Old Jun 23, 2004 | 05:22 PM
Luther6704's Avatar
Car: 1986 Iroc
how so? i was more worried about stripping the case out or cracking it then snapping the bolt. Is there some chart to follow. Like troque of the bolt is determined by the size of the head? or how many threads are on a bolt? or the diamater of the bolt? or the grade of material of what the bolt was made of? This seems very interesting. Ill torque them to 35 ft lbs.
Old Jun 23, 2004 | 06:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's determined by the diameter and thread pitch of the bolt, or more accurately, the necessary clamping load determines the fastener properties, and therefore the torque needed to tighten the fastenr to the point needed to produce the desired clamping force.... if it needed more or less clamping force, proper design technique would be to use the right size fastener.
The bolt head size is typically determined by the size of the threaded part, to allow for the proper torque to be applied to it without failing.
The need for a higher grade of bolt is usually determined by forces other than mere tightening that the bolt might have to deal with in normal operation.
Old Jun 23, 2004 | 08:29 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Well, My daddy always said to tighten 'em up till they break off and then back 'em off a turn. LOL.....
Old Jun 23, 2004 | 09:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Smart guy!!!
Old Jun 24, 2004 | 07:53 AM
Luther6704's Avatar
Car: 1986 Iroc
Where can i find more information? That totally blew my mind. To think that a simple bolt is designed to such strict standards for specific applications. Where i can find more technical info about anything that i should probably know. Is there websites that i can learn from or do you have to go to school to know about that kinda stuff?
Old Jun 24, 2004 | 08:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I don't know about web sites; there probably are some though. You can learn an amazing amount of stuff if you just look through catalogs of people that sell them, and look at their ratings and stuff.
You learn more about that sort of thing than you probably want to know if you study mechanical engineering in college.
Old Jun 24, 2004 | 07:55 PM
Luther6704's Avatar
Car: 1986 Iroc
haha i was teetering on either a business major or an engineering major. Thanks
Old Jun 25, 2004 | 06:12 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Tailshaft housing bolts
Get a 10.5" or 11" ratchet. Put your strongest hand on the very middle of the ratchet. Crank away.
You're good.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
