POS 700r4 has bad shift points need suggestions
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
I just finished getting my 340hp 350 to run right and now Ive finally realized what ****ty shift points the 700r4 has. It shifts hard but seem like it cant make up its mind at what rpm it wants to shift at and i dont even like the way it shifts is there anything i can buy or do to adjust shifting or buy a 98-02 Fbody trans (will it fit bolt pattern?) beacuse they shift VERY right for my tastes but thats alot of money. Also when i did the motor swap the trans had no wires connected to it i thought they were partially computer controlled??
Car: 1987 IROC-Z
Engine: 305 LB9
Yea its hooked up I keep adjusting it to see if i can make it better i gotta keep playin with it.
Car: 1987 IROC-Z
Engine: 305 LB9
Yea its right but the trans shifts at like only 5000rpm i need it to shift at like 6000.
Car: Camaro
Engine: 6.2L
Thats a governor valve issue then. That ones not so easy and will require some valve body examination and mods. Better take it to a reputable performance tranny shop or just shift manually.
Car: 1987 IROC-Z
Engine: 305 LB9
so now that i think about it thats a big thing with the shifting. i found 50ft of tread marks before it shifted. Trending Topics
Car: 1987 IROC-Z
Engine: 305 LB9
I already have lakewood lca's i need to get a posi rear first then i was going to get lca relocation brackets and subframe connectors.
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Car: 1987 IROC-Z
Engine: 305 LB9
I did all the work myself i dont let other people work on my car no fun in letting other people do the work besides i cant afford it.
