Holly Bracket
Old Jul 10, 2004 | 10:41 PM
korndogg's Avatar
Car: 1968 Camaro
Engine: 327
Holly Bracket
I dont know if you guys can help me but i figured id try. I got a tv cable bracket for my holly carb. i have no idea where it goes? the only place it seems to fit is under the back left bolt of the carb. but wouldnt the carb be lifted up then? im so confused.
Old Jul 10, 2004 | 11:53 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
If you have carb studs, it goes on top of the back left lip of the carb, not underneith.
Old Jul 11, 2004 | 12:09 AM
korndogg's Avatar
Car: 1968 Camaro
Engine: 327
hey thanks alot man...i had the damn bracket upside down so that tab by the carb was facing down. i feel like such an idiot.
Old Jul 11, 2004 | 12:14 AM
korndogg's Avatar
Car: 1968 Camaro
Engine: 327
oook...not fixed....my bracket is backwards from yours.....ill take a pic..
Old Jul 11, 2004 | 12:20 AM
korndogg's Avatar
Car: 1968 Camaro
Engine: 327
when mine is the same way as yours the tab is facing down...can i just cut that tab off?
Old Jul 11, 2004 | 12:32 AM
TA5LiterHO's Avatar
On the double pumper carbs there is a notch that that fits into. It keeps the bracket from being moved around by the preasure of the throttle cable. On Vacuum Secondary carbs like the one I am running there is no notch, so I made one. The metal is real soft on the carb baseplate.
You need to keep that tab so the bracket will stay secure. You could cut the tab off and just crank the bolt down, but then you risk warping the baseplate on the carb from overtightening and the bracket will probably still move.
You have it the right way when the bigger hole is on the bottom.
Here's a pic from when I had the Double Pumper on there. You can see the difference in baseplates that allows that tab to fit in there.
Old Jul 11, 2004 | 12:35 AM
korndogg's Avatar
Car: 1968 Camaro
Engine: 327
so basically your saying that i have to grind down a piece of the carb right? howcome in ur pic it looks like the tab is going up?
Old Jul 11, 2004 | 12:38 AM
TA5LiterHO's Avatar
It's down, it got bent up by accident at one time and I bent it back so there's a light spot on the metal now. That may be what makes it look that way. I edited in another pick in the previous post.
Old Jul 11, 2004 | 12:41 AM
korndogg's Avatar
Car: 1968 Camaro
Engine: 327
so i can grind down the baseplate and it should be fine?
Old Jul 11, 2004 | 12:46 AM
TA5LiterHO's Avatar
Here's another pic with the Double Pumper.
Notice how theres a spot on the baseplate that's notched in? If you take the carb off and make a notch in the same location(the spot where the tab lands when you set it on there) it should work perfectly, just be careful not to cut too far into where the carb mates to the intake.
Old Jul 11, 2004 | 12:47 AM
korndogg's Avatar
Car: 1968 Camaro
Engine: 327
ok yeah...
one more question. do i have to get that geometry adjuster thing?
i have the tv cable..and the bracket..thats it
Old Jul 11, 2004 | 09:24 AM
TA5LiterHO's Avatar
Here's a link to the Universal TV cable I have which is much easier to adjust and fine tune than the factory one.
http://www.transmissionhead.com/
Holley also has a bracket that bolts to the throttle linkage on the carb so that the TV cable hooks on in exactly the right location.
This is the geometry bracket you were talking about right? It does help keep things adjusted right. If you are using the factory cable and can adjust it so that it pulls out at the right rate and at the right time then you can do without it, but I would suggest ordering one to make life easier.
It makes the adjustment easy and it ensures that you have your trans adjusted cexactly right.
http://www.partshp.com/Holley.htm
Old Jul 11, 2004 | 02:08 PM
korndogg's Avatar
Car: 1968 Camaro
Engine: 327
well the tv cable i have is the B&M universal one. it seems too short tho but it says it works in 95% of applications. its gonna be close. i got it from summit.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
