help with 9-bolt
Old Jul 19, 2004 | 10:26 PM
matt formula's Avatar
Car: 1990 firebird formula
Engine: V8 305 TBI
Transmission: TH700R4
help with 9-bolt
I bought a 9-bolt posi that I'm going to swap in for my crappy 10-bolt this weekend, but I just noticed the other day that when you turn the passenger side axle there it about a 1/4in of play before the yoke turns but when you turn the driver side axle the yoke turns right away. Is this ok? if not how bad is it?
Old Jul 20, 2004 | 08:39 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Does this happen only on the one side or is it consistent for both?
Old Jul 20, 2004 | 10:39 AM
Engine: V8 305 TBI
it only happens on the passenger side
Old Jul 20, 2004 | 11:11 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Seems odd then. Pull the diff cover off and check for backlash and axle play. Wouldn't be a bad idea to examine the carrier while you have it open either. There is a good article at TGO home page tech for doing this.
Old Jul 20, 2004 | 11:17 AM
JA_Formula_89's Avatar
Car: 89 Formula
Engine: 5.0 TPI (F-Code)
Transmission: 5 Speed Manual
Does it happen all they way around the rotation the same or are there loose spots and tight spots. Posi behaves a little funny if you don't know what to look for, so I wouldn't read too much into it.
Old Jul 20, 2004 | 05:04 PM
Engine: V8 305 TBI
it seems to happen in only one spot
Old Jul 20, 2004 | 09:25 PM
Car: 89 Formula
It sounds like you could possibly have some bad teeth on your gears. Can't be sure though.
If you turn it round and round by the yoke do you notice any spots where it jams or makes noise? The ends of the axle will have to be free to turn. Turning a posi rear by the ends can be confusing. It tends to lock and without the wheels on there you don't have much torque.
This is out of the car right? Open it up and take a look inside. Clean it out and examine the teeth and everything else really closely. Look for remains of broken parts in the bottom.
Where did you get the axle from?
If the axle has high miles on it now might be a good time to rebuild it.
Old Jul 21, 2004 | 12:36 PM
Engine: V8 305 TBI
when I turn the yoke both axles turn freely, there are no spots where it becomes more difficult to turn, and I took off the rear cover and inspected the gears and there are no broken teeth or anything, it all looks good. I was told by the guy I bought it from that it has about 80,000 miles on it
ZMWojnar
Brakes
May 12, 2019 10:43 PM
6speedIROC
Sep 13, 2015 01:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
F-Messenger
Carburetors
Nov 14, 2001 04:28 PM
