got a big problem,help please
Old Jul 27, 2004 | 12:09 AM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
ok i changed my 10 bolt drums to a 9 bolt disc,before it ran fine,now i finished last night and i tried to test it out by taking it to work and heres whats wrong:the speedometer says 110 when going with flow of traffic on freeway.when i let go of gas it fells like its downshifting,and when i get to a certain stable rpm it gives a weird kick in the rear,its wierd,please help
Old Jul 27, 2004 | 08:32 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
anyone?
Old Jul 27, 2004 | 11:54 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
drums to disc
need more input did u use same rear end or did you switch and what about spider gears or is there anyway you could have mixed up parts.or maybe left a thrust or 2 out. sounds like spider gesrs 2 me ....If I had 2 guess
Old Jul 27, 2004 | 11:57 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
p.s.
It also could have something 2 do with clutch pack? like I said more onfo would help
Old Jul 28, 2004 | 12:05 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
What was the gear ratio of the 10 bolt rear and what is the gear ratio of the 9 bolt you have in now. When you change gear ratios you have to change speedometer gears in the transmission.
Old Jul 28, 2004 | 01:22 AM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
i switched the whole rear itself,and i dont know the stock gears but the 9 bolt is 3.70 or 3.73 i forgot i dunno wats wrong
Old Jul 28, 2004 | 07:38 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
The stock gear ratio was probably 2.77 or 3.08 since your speedo is so far off. You need the change the speedo gears for your new ratio. Go here to find out what gears you need:
https://www.thirdgen.org/newdesign/f...n.shtml#tranny
or
http://www.tciauto.com/tech_info/speedo_gears.htm
Old Jul 28, 2004 | 10:27 AM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
so a new speedometer gear would fix that problem,but how about the way it acts in the rear
Old Jul 28, 2004 | 11:01 AM
DonP's Avatar
Car: 1990 GTA Black/Black lthr
Engine: 305 TPI stock
Re: got a big problem,help please
Changing the gear ratio makes the car accelerate faster. When you let off the gas, it also makes it decelerate faster.
You need to explain the weird kick in the rear better. I'm thinking it might be a u-joint issue. Also, check your drive train alignment. I can't remember where, but I read a magazine article about checking to make sure everything is in a straight line from the tranny to the rear end. If your stuff has really bad angles, that might be something you need to fix with shims.
Old Jul 28, 2004 | 11:40 AM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
well its like someone hit you from the back, like a lil impact that made me jump when it happened,actually i still jump when it happens
Old Jul 28, 2004 | 12:44 PM
DonP's Avatar
I can't help, but for someone else who might be able to help, does it do this impact once when you get to a stable speed, or does it constantly do it, or does it do it as you go from speeding up to slowing down or vise versa?
I'd be careful driving it too much until it's fixed. It doesn't sound good.
Old Jul 28, 2004 | 04:28 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
You need to explain your problem more so the solution will be more evident. Does the kick happen at a certain specific speed? Does it happen constantly or just randomly?
Actually it may.
Depending what engine and computer you have the stock computer PROM on some setups is configured to lock the torque converter clutch around 75-80 MPH no matter if you are at wide open throttle or no throttle at all and it will remain locked above that speed. Also it is configured to lock the TCC around 35 MPH depending on TPS and a few other things. So if you speedo is reading 110 MPH on the highway so is your computer. That means the computer will lock the TCC much much sooner then if you had the right speedo gears in it. A quick way to see if it is the TCC locking causing the knocking problems is to unplug the 4 pin connector from your transmission and see if it goes away.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
