Is there way to tell what gears I have?
Old Aug 23, 2004 | 09:27 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
A friend's got a '91 Z28 with a 350. The sticker (I can't believe he still has it, lol) says Performance Package on it I think. It's Posi....is there a way to tell what gearing it has? Can anyone guess?
Old Aug 23, 2004 | 09:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only way to know for sure would be to take the cover off and count the teeth.
Old Aug 23, 2004 | 09:59 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
yep after this long, our cars could have had the gears changed a few times.
just pull the cover and count
kretos's Avatar
Car: 89 Iroc
Engine: lb9
oh and with it off change the fluid back there
kretos's Avatar
Car: 89 Iroc
Engine: lb9
double post sorry
Old Aug 24, 2004 | 09:12 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Well I'm pretty sure these are the original gear. Can anyone give me a rundown of what gear choices came with Posi in '91?
Old Aug 24, 2004 | 09:21 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
well, there was a pretty wide variety. do you have the original RPO sticker? if so, go to the RPO decoder and decode the GU? codes. like, for instance, mine was GU2 which is the "dreaded" 2.73 gear ratio. so just go decode whatever you have...or if you don't have it, then get to countin' son. actually, if you wanna go through the trouble, there is another way...you get a paint marker, put a mark on the driveshaft, and make a mental mark on the tire, line it with a mark on the car. spin the driveshaft one turn, and count how many times the wheel rotates. 2.73 times, 3.73 times...you get the idea...you most likely have 3.42's if your car is all stock...that seems to be fairly popular in the 92s...should be 3.42's if ya got the G92 package...3.08's should be standard, although 2.73's were still available...
Josh
Old Aug 24, 2004 | 10:18 PM
cjmelendez's Avatar
Car: 82 trans-am
Engine: 305 4bbl q-jet
If you guys don't mind me asking here but how about for an 82 trans am, what was the gear ration for an 82 I swapped my 200c for a 700r4 and now my speedometer is about 12 to 15 mph off above the car's actual speed. I was told I need to change my speedo gear but I need to know the rear end ration to see what gear I need.
Thanks everyone
Chris
Old Aug 25, 2004 | 02:38 AM
well, now on that, unless you have an option sticker you will have to either count teeth or use the method i listed above...good luck guys...
Josh
Old Aug 25, 2004 | 05:53 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
You could also pull the cover and look on the side of the ring gear and it should be stamped on there. Is there a tag on the rear cover?
Old Aug 25, 2004 | 09:32 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Thanks Screamin'! I'll try the methods you described!
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
