700R-4 Possible Problem????????
Old Sep 7, 2004 | 04:06 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
Read Me.....Read Me.....
While I am a good mechanic, I know little about automatic transmissions. My car has under 100,000 miles. Original tranny. I have noticed that under very light throttle, the one-two shift is kind of hard. Cable was re-adjusted after I changed the intake gaskets last month. Filter/fluid were recently serviced.
From what I have read, the cable adjustment may not be as easy/straight foward, as described. Too much pressure will cause rough shifting, and too little will not be enough to prevent clutch slippage and wear. Am I missing something in the cable adjustment procedure? I see that the servo is supposed to fully retract when releasing the cable, during the adjustment procedure. Do I have a problem, or are the observed symptoms absolutely not a concern? I have my fingers crossed. I have looked for the answer with a search, but cannot find suitable text concerning this issue.
Old Sep 7, 2004 | 08:13 PM
bobsroc's Avatar
Car: 1987 IROCZ
I found some info this weekend that helps explain the 700r4, I'll email them to you. Hope they help.
Old Sep 7, 2004 | 08:16 PM
Very kind of you.
Seth
Old Sep 7, 2004 | 08:27 PM
It is wonderful when others are nice.
Old Sep 7, 2004 | 08:40 PM
bobsroc's Avatar
Car: 1987 IROCZ
No problem. Glad to be able to help another fellow car lover. I wish we all could play this nice!!
Old Sep 12, 2004 | 08:33 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Hey bobsroc, could you send me this info too? My tranny seems perfectly fine, as i am having no problems, but its always nice to have some good info to fall back on just in case. My email is yarwood89@hotmail.com. It would be greatly appriciated.
Old Sep 12, 2004 | 08:59 PM
bobsroc's Avatar
Car: 1987 IROCZ
There on the way!!
Old Sep 13, 2004 | 09:42 PM
kd5boc's Avatar
Car: 92 RS
Add another one to your list...
check your PM...
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
