how much can a t-5 handle?
Old Sep 9, 2004 | 10:45 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok so i am wondering just how much a t-5 can handle. i am planning on just a little hop up on my 305tbi.
Old Sep 10, 2004 | 12:40 AM
nsimmons's Avatar
people say not much, people say a lot, im maiking just over 300hp or so, mines fine, dont power shift it.
Old Sep 10, 2004 | 01:14 AM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
like nsimmons said, they hang in there, so long as you don't beat on them too much. My 305 is hovering around 240 ftlbs, and with 120k on the clock I'm just now sarting to detect some bearing noise. A decently equipped 377 will be under my hood by Oct. though. That will be the real test!
Old Sep 10, 2004 | 09:27 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your T5 should be okay begind your 305 TBI. Powershifting, clutch drops and slicks kills these trannies.
Old Sep 10, 2004 | 08:07 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
strong t5?
Davieboy ur gonna rip tht tranny apart wtha 377...ud hve to take it super easy.. go wtha t56...theyre a lot stronger, ths guy harris from racersden is puttin 450hp at the wheels and his tranny is fine
Old Sep 10, 2004 | 09:00 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
There is a company in PA that makes a set of gears for the t5 that they claim will handle like 500 ft lbs.
www.g-forcetransmissions.com
Old Sep 10, 2004 | 09:20 PM
Dave's 89's Avatar
Car: 89 IROC-Z
Re: strong t5?
Oh yeah, i'm counting on it. I'll probobally save my pennies for a TKO rather than a used t56
Old Sep 11, 2004 | 09:02 AM
Souseless's Avatar
Car: 89 WS6
Check out the link from my last post. It is stronger than a TKO and it is cheaper. The TKO is only good for slightly more tourqe than the T5 so it is not that much of an upgrade. By the way I know someone that has been road racing with a T5 and a 377 for many years and has only had problems with 5th gear. This is certainly not the same abuse as a drag launch, but it shows that in street use the tranny will hold up.
Ken
Old Sep 11, 2004 | 02:05 PM
nsimmons's Avatar
the tremec is rated for 500ftlbs? Thats not much of an upgrade over the t5?
Old Sep 11, 2004 | 02:28 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
the TKO is rated for 500 ft pounds...the GM WC T-5 is rated for 330 ft pounds...the G-force T-5 is rated 600 ft pounds..i have experiance with these trannie and i can tell you FIRST hand they WILL hold up behind OVER 700 HP
PurelyPMD
May 5, 2016 04:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
