Help with TV cable adjustment
Old Sep 16, 2004 | 07:34 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I followed the tech article on this board for this adjustment. However, after I have pushed the plastic thingie back all the way and release the tang, the cable does not click (I hear no clicking) as I move the throotle to WOT.
What is the problem?
Edit: Another question would be: If the plastic slider is pulled out more toward the throotle WOT, does this make the tranny kick down harder or hardly at all?
Old Sep 16, 2004 | 08:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
With the throttle completly open, press the 'D' shaped tab and pull the TV cable housing all the way back to the firewall as hard as you can (but not so hard that you break it). Release the tab and close the throttle. With the throttle opened all the way back up the cable should be nice and tight. If its loose or it ratchets way back out then theres something wrong. If you cant get the cable to adjust properly then dont drive the car untill you fix it.
Old Sep 16, 2004 | 09:18 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I did a search and found that method. I did that and the tranny shifts harder and shift at higher RPMs. Just what I needed.
Thanks for the reply.
Old Sep 16, 2004 | 09:57 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
I just did that method too and took my car out for a rip run.
HOOOLY CRAP! That trans shifts a ton harder and it actually shifts normally while driving now. That's the last time I use the Haynes' manual's method.
Old Sep 19, 2004 | 05:38 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Just maybe this method should have a tech article written up and saved in the tech article area.
Old Sep 20, 2004 | 07:37 PM
IroczInOz's Avatar
nape I read the Haybes manual too and it saysa to do it just like what dimented 24x7 said to do it. So maybe you read it wrong.
Old Sep 20, 2004 | 08:41 PM
Car: 88 Camaro SC
Engine: SFI'd 350
They may have updated the manual. Ive seen that method in other manuals. I dont know why its there. It didnt work at all for me.
Old Sep 21, 2004 | 07:33 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
I just got my new t.v. cable at work today, and i asked one of the fellow mechanics how to adjust it. He said the same method. This is gonna be cool. I hope my car shifts better than with the old cable. You could feel it shifting, but it was wimpy. It also seemed to shift way too early. I hope this will make it a ton better.
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
